09-19-2017 05:09 PM
the SKU MA-CBL-40G-1M shows 2 ports on each end of the cable, which would tell me I would only use 1 stacking cable to connect 2 switches. is that correct?
Solved! Go to Solution.
09-19-2017 05:46 PM
Correct. If the switches are going to be right next to each other you'll be able to use the shorter stacking cables such as MA-CBL-40G-50CM (this is assuming you are using a switch with 80Gb/s of stacking [aka 2 x 40Gb/s cables] like an MS225).
09-19-2017 05:15 PM
Negative. You need two cables to create a ring.
09-19-2017 05:37 PM
just to be clear... QTY 2 of MA-CBL-40G-1M are necessary to stack 2 switches?
09-19-2017 05:46 PM
09-19-2017 05:50 PM
OK. thank you. the documentation and the visuals are rather lacking. it was hard enough to get a picture of the stacking cable.
I did mention the 50cm cable as an option to the customer but he wanted 1m just in case.
Per my subject line I am using the MS250-48FP-HW switches in this case.
thank you,
John
09-19-2017 05:53 PM
The MS250 also uses an 80Gb/s stacking connector so uses the same cables.
The cables are not that expensive compared to the switches. I often include extra cables because of this. Having an extra unused cable is much easier than having a cable too short and is unusable.
09-19-2017 06:12 PM
This is a good article about connecting up physical stacks.
https://documentation.meraki.com/MS/Stacking/Configuring_a_Physical_Switch_Stack
09-19-2017 06:16 PM
yes, I actually already looked at that and was part of what I was talking about documentation earlier.
It shows one line from one switch to the next. then a second line from the bottom switch to the top switch, implying two different cables; however, the SKU itself has 2 cables as part of the assembly, hence my confusion. I did not find an actual picture of the back of the switch (not an architectural picture) that has the detail showing if each port is actually broken into two parts or not.
10-19-2018 05:19 AM
10-19-2018 10:08 AM
If you want to stack them use two stacking cables.
Otherwise you could just connect then with an Ethernet cable.
10-19-2018 10:16 AM
thank you for your answer, but it is not the same, an ethernet cable would give me a 1Gbps link, while the stacking gives 40Gbps.. I know having two cables is the best, but I´d like to know if having only one could work?
Thank you again!
10-19-2018 10:19 AM
10-19-2018 10:33 AM
Understood! thank you @Philip D'Ath
07-30-2021 01:10 PM
I also wasn't sure if I needed two cables for my stacks of two switches so I went with one cable and it works perfectly fine. No errors in the dashboard or anything. My stacks are of two MS225 and two MS250 switches. I guess I should order the 2nd cable?
07-31-2021 02:07 AM
@watdee you may get errors if you reboot the stack, or you.may be lucky. I'd definitely get a second cable!
