how the computer detect connection speed end-to-end
mohammed hashim
hi,
when you have to computers want to communicate over the network like:
HostA-----------R1----------R2-------10Mb---------R3--------------R4-------------HostB
so the bottleneck of this connection is 10Mbps,
how these Hosts can detect the bottleneck before they start sending traffic !?
Philip D'Ath
Before sending any traffic - they can't.
how then they realize it after sending !?
They could generate synthetic traffic to measure it.
They could just send traffic normally, and if they exceed the link capacity wait for packets to be dropped, and back off, like normal TCP.
If the routers supported it, they could also use explicit congestion notification.
https://en.wikipedia.org/wiki/Explicit_Congestion_Notification
If they needed guaranteed bandwidth and the network was configured for it they could also try using RSVP.
http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfrsvp.html
thanks a lot,
I will check these links
