front panel view of cisco 2950
susanta4ever
Hi.. whenever I login into my switch 2950 from web browser,front panel view of cisco 2950 is not showing...The Front Panel view is a graphical display of the switch front panel. The display shows all the switch components color-coded according to their status. The colors can help you to quickly see if a faulty condition or an error condition exists...As it is disappear, I cannot check the graphical view of port status.. So please tell me how to recover the view..
5 Replies 5
saifhusain
Can you check & confirm these 3 possibilities .
1) Does the user have Privilege level 15 access?
2) Did you check with other browser? (Chrome, IE)
3) Is Java up to date?
Saif
yes i have privilege level 15 access
already checked with different browsers
java is up to date...
thanks
susanta
Hi Susanta,
To me this seems to be a system specific issue. Can you please follow the below steps & confirm:
Open Start > All Programs > Accessories > System Tools > Internet Explorer (No Add-ons)
Do not enable any add-on, then try to access the gui of your switch & confirm, if this resolves the issue.
Hi Susanta, it looks like you are having trouble because of your Web Browser, first please try checking with a different browser to eliminate this possibility.
Hello
I agree I dont think its the switch, more than a browser incompatibility
res
Paul
Kind Regards
Paul
