How to Abort Traceroute Execution?
sharone.job
     How can I abort the traceroute execution, when the IP route fails somewhere?
Tracing the route to 10.6.177.68
  1 10.148.50.73 4 msec
    10.148.64.1 4 msec
    10.148.50.73 4 msec
  2 10.148.65.1 4 msec 4 msec 8 msec
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
30 Replies 30
Jonathancert_2
CTRL+SHIFT (together) and the number 6.  Sometimes you have to hit 6 repeatedly.  It will abort but you have to catch it early in the process.   I have found that after traceroute has completed three processes, the command won't take.
Jonathan,
Hi Jonathan,
    Thanks for your suggestion, hmmmm but its not working here
I had tried earlier also; and now as suggested, early in the process. Still its not stopping.
Sharone
Hi Sharonee,
Try this
Ctrl + Shift + 6 + x
Ctrl + Shift + 6 shoul work as Jonathan said. But rather try this one.
Faisal
Sorry Guys,
its not working. Earlier when I googled, I got the same solution. From that time onwards I am trying this, but no way out.
Faisal, as suggested I tried a few times just now, still the problem stand still.
Any other Idea??
Sharone
Try holding down ctrl+shift and then hit '6' and 'x' same time couple of times. Make sure the mouse courser stays with in
router/switch session.
hth
MS
Hi Guys,
     Ctrl + Shift + 6 or Ctrl + Shift + 6+x didnt worked on my PC.
But Ctrl+C+6 worked !!
I donno whether it depends on the keyboard or something, but it worked !!
Thanks everyone !
Sharone
That's good news.  One less thing to worry about on a Friday.  Will try your commands on my next traceroute and see what happens.
Jonathan,
Hi Sharone,
Ctrl+C+6
Worked on single time Entry rather than Ctrl + Shift + 6 or Ctrl + Shift + 6+x multiple  times
That's perfect.
CTRL + C + 6 works well.
Know this thread is old but Ctrl+c+6 worked on the emulator provided by Cisco (thank goodness :)
Both the following work for me (with PuTTY to the console of a 1921) : CTL + 6, CTL + SHIFT + 6
CTRL + c + 6 also appears to work, but CTRL + c by itself does nothing.
Yes, Ctrl + C + 6 is working. Thanks whoever shared this key combination.
What Cisco device are you working on?
Jonathan,
Hi Jonathan,
          Its Cisco Router 7609-S.
Sharone
