how to accept traffic from Cisco Router 2921 on Cisco ASA 5510
ladipol01
I have a Cisco Router 2921 configure by ISP and pass traffic to my Cisco ASA 5510 how can I configure the ASA 5510 to accept the traffic for my LAN usage.
Thanks in advance for response.
9 Replies 9
johnd2310
Level 8
Level 8
How is the 2921 passing traffic to the asa? are you using a routing protocol or static routes? are you using nat or not? a basic description of your setup would help.
you will need to configure an outside and an inside interface on the asa. configure routing on the asa to forward traffic to the asa and internal router if present.Configure nat if required.
John
**Please rate posts you find helpful**
Hi John,
Thank you for your response.
Answer: This has not been done yet. I want to know how it can be done using CLI
Answer: i am using static routes
Answer: I am using nat
An inside and outside interface has been configure on ASA
How can this be done using CLI
Ladipo
ASA
route outside 0.0.0.0 0.0.0.0 x.x.x.x where x.x.x.x is the ip address of the 2921 interface connected to the asa.
nat configuration will depend on the version of code on the asa, but pat config might look like this:
object network my-inside-net
 subnet y.y.y.0 255.255.255.0
 nat (inside,outside) dynamic interface
thanks
John
Hi John
Thank you for the response
I want to use NAT below is the version of the ASA
Cisco Adaptive Security Appliance Software Version 8.2(5)
What code can i use for the NAT
Ladipo
if you are using 8.2(5) then the nat config will be similar to this:
nat (inside) 1 192.168.1.0 255.255.255.0
global (outside) 1 interface
This sample config assumes you are you are using 192.168.1.0 255.255.255.0 as your inside network.
John
Hi John,
I also wan to use port 83 how will i do that in the  code.
Ladipo
I don't understand what you mean with port 83. What do you want to do with port 83?
Hi John
That is the port on LAN ip address 192.168.1.25 which is the destination of the traffic coming from the ASA to the LAN.
Ladipo
Hi John,
What i want to do is to port forward port 83 to server ip address 192.168.1.25 on the LAN. The inside ip of ASA is 192.168.1.21 and the outside ip of the ASA is 10.*.*.2 both on subnet 255.255.255.0. The server ip is NAT to 10.253.1.2.
Ladipo
