how to access asdm asa 8.4 from outside interface ?
Dr.X
Level 2
Level 2
hi all ,
i changed default http port of asa to 65000
from lan ,
i can access it from asdm by :
10.10.10.10:65000
but the question is ,
how access the asdm asa from the outside interface ???
wt rules should be allowed ???
i cant access it from outside with 144.145.7.x:65000
regards
smoores
Did you try:
management-access outside
http server enable
http 144.145.7.x x.x.x.x outside
hi ,
i did ,
thesame issue
ihave
http server enable 65000
http 0.0.0.0 0.0.0.0 outside
on the asdm i put the ip x.x.x.x:65000
but on the asdm
it say ,
"contacting with server"
and there is no login after that ?!!!!
do i need to modify my access rules to allow ?
reagards
