Why cisco WS-C4506-E Switches High CPU???
topnewinfo
Hi I have an unusual behavior on Catalyst 4506E switche. The cpu utilization is 35%
The process K2FibAdjMan Host Mov is consuming HIgh ressources....
Does anyone have any suggestion?
Thnaks a lot
JT-4506-1#sh proc cpu so 5se
CPU utilization for five seconds: 32%/0%; one minute: 30%; five minutes: 31%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  58   8818750353707169302          0 21.19% 17.64% 18.35%   0 Cat4k Mgmt LoPri
  57  2535818316 443647374       5715  7.27%  7.83%  7.88%   0 Cat4k Mgmt HiPri
109   431437899 749682568        575  0.79%  0.93%  0.98%   0 IP Input
  14   2890879741522020496        189  0.47%  0.61%  0.59%   0 ARP Input
116   103254436 378426195        272  0.39%  0.39%  0.39%   0 Spanning Tree
112   2657381781294108349        205  0.31%  1.06%  0.86%   0 ADJ resolve proc
JT-4506-1#sh pl health
                     %CPU   %CPU    RunTimeMax   Priority  Average %CPU  Total
                     Target Actual Target Actual   Fg   Bg 5Sec Min Hour  CPU
this is unusual:
K2L2 Address Table R   2.00  18.99     12      5  100  500   12   9    7  51455:59
K2FibAdjMan Host Mov   2.00  12.43     10      7  100  500    8   8    7  11238:47
JT-4506-1#sh mac add aging-time
Vlan    Aging Time      Configured Aging Time
Global Vlan Admin Age: 300
   1    300             300
100    300             300
300    300             300
500    300             300
501    300             300
502    300             300
503    300             300
600    15              300
why vlan600 aging time is 15sec??  no edit
JT-4506-1#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(54)SG, RELEASE SOFTWARE (fc3)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 27-Jun-10 00:29 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123F21AC
ROM: 12.2(31r)SGA3
Pod Revision 16, Force Revision 31, Tie Revision 32
cisco WS-C4506-E (MPC8540) processor (revision 13) with 524288K bytes of memory.
Processor board ID FOX1524GGAV
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
6 Virtual Ethernet interfaces
106 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Steve Fuller
Level 9
Level 9
My guess would be that you have a spanning tree issue which is causing topology changes in the network, hence the MAC address moves and the short aging timer i.e., the same value as the forward delay, being seen for VLAN 600.
If you run the show spanning-tree vlan 600 detail command the first few lines of the output will indicate the number of topology changes that have occurred, when the last one was and the interface it was received from.
hi steve
I don't know where the problem.
VLAN0600 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 24576, sysid 600, address 0007.7dc5.cc80
  Configured hello time 2, max age 20, forward delay 15
  We are the root of the spanning tree
  Topology change flag set, detected flag set
  Number of topology changes 133150 last change occurred 00:01:55 ago
          from GigabitEthernet3/11
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 1, topology change 27, notification 0, aging 15
sh spanning-tree interface gi3/11 de
Port 139 (GigabitEthernet3/11) of VLAN0600 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.139.
   Designated root has priority 25176, address 0007.7dc5.cc80
   Designated bridge has priority 25176, address 0007.7dc5.cc80
   Designated port id is 128.139, designated path cost 0
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
   BPDU: sent 31838426, received 441659
sh run inter gi3/11
interface GigabitEthernet3/11
switchport private-vlan host-association 600 610
switchport mode private-vlan host
end
sh mac add inter gi3/11
Unicast Entries
vlan   mac address     type        protocols               port
600    0014.5eac.777d   dynamic ip                    GigabitEthernet3/11
600    001a.4be1.e284   dynamic ip                    GigabitEthernet3/11
600    001a.6c67.2a2f   dynamic other                 GigabitEthernet3/11
Multicast Entries
vlan    mac address     type    ports
600    0100.5e05.0505     igmp Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
                                Gi3/8,Gi3/9,Gi3/10,Gi3/11,Gi3/12,Gi3/14,Gi3/16
                                Gi3/17,Gi3/18,Gi3/19,Gi3/20,Gi3/21,Gi3/22
                                Gi3/23,Gi3/24,Gi3/26,Gi3/27,Gi3/36,Gi3/39
                                Gi3/41,Gi3/42,Gi3/43,Gi3/44,Gi3/45,Gi5/1
                                Gi5/2,Gi5/3,Gi5/4,Gi5/5,Gi5/6,Gi5/7,Gi5/8
                                Gi5/9,Gi5/10,Gi5/11,Gi5/12,Gi5/13,Gi5/14
                                Gi5/16,Gi5/17,Gi5/19,Gi5/20,Gi5/21,Gi5/22
                                Gi5/23,Gi5/26,Gi5/28,Gi5/29,Gi5/31,Gi5/32
                                Gi5/33,Gi5/34,Gi5/35,Gi5/36,Gi5/37,Gi5/38
                                Gi5/39,Gi5/40,Gi5/41,Gi5/43,Gi5/45,Gi5/47
600    0100.5e26.4cda     igmp Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
600    0100.5e6f.700c     igmp Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
600    0100.5e7f.ff64     igmp Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
600    0100.5e7f.fffa     igmp Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
600    0100.5e7f.fffd     igmp Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
600    ffff.ffff.ffff   system Gi2/4,Gi2/6,Gi3/1,Gi3/2,Gi3/3,Gi3/4,Gi3/5
                                Switch
The switch you captured the above commands on is the root bridge for the spanning tree, and the switch connected to interface gi3/11 is the device generating the Topology Change Notification (TCN) and then sending to the root bridge.
Can you login to the downstream switch that is connected to interface gi3/11? If so then run similar commands on that switch and see which port is causing the topology changes. It may be that you have a port that is continually changing state.
If it's an access switch, then changing the port type to an edge port i.e., enabling portfast, will stop the TCN being generated.
Thank you, I try.
