How to access bash terminal on cisco Nexus 5696 Chassis?
How to access bash terminal on cisco Nexus 5696 Chassis where I can run simple commands a like ls, pwd, ifconfig etc Edit
Hardware
Thanks & regards,
Nilesh Bhadane
7 Replies 7
balaji.bandi
Do not have access to 5696, but our nexus 9K we can do as below :
switch# guestshell
BB
lab04-ed01# guestshell
Error: Guestshell not supported in this release
I am getting this error
in addition to the other post, you might also try:
N5696# configure terminal
N5696(config)# feature bash-shell
N5696# run bash
lab04-ed01(config)# configure terminal
lab04-ed01(config)# feature bash-shell
% Invalid command at '^' marker.
lab04-ed01(config)#
I am getting above error
Can you post show version
BB
Hi, @balaji.bandi
Show version output -->
lab04-ed01# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2017, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 2.1.0
Power Sequencer Firmware:
Module 1: v1.0
Module 1: v1.0
Module 2: v1.0
Fabric Power Sequencer Firmware: Module 0: version v3.0
Microcontroller Firmware: version v1.2.2.0
QSFP Microcontroller Firmware:
Module 1: v1.7.0.0
Module 2: v1.7.0.0
Module not detected
CXP Microcontroller Firmware:
Module not detected
kickstart: version 7.3(2)N1(1)
system: version 7.3(2)N1(1)
BIOS compile time: 09/01/2014
kickstart image file is: bootflash:///n6000-uk9-kickstart.7.3.2.N1.1.bin
kickstart compile time: 5/12/2017 23:00:00 [05/13/2017 04:15:12]
system image file is: bootflash:///n6000-uk9.7.3.2.N1.1.bin
system compile time: 5/12/2017 23:00:00 [05/13/2017 04:16:49]
Hardware
cisco Nexus 5696 Chassis ("Nexus 5696 Supervisor")
