How to access standby super visor engine
I have a 6504 with dual sup-engine. I would like to access the standby sup-engine remotely. Kindly advise. Thanks.
Gab
Hi Joseph,
I just got the correct command to do it.
remote login standby-rp
Gab
Joseph W. Doherty
You can access the standby sup using a session command (NB: I know you can access it, as I've done it, but I'm not 100% positive it's the session command). However, once you gain access to the standby sup there not much you can do beyond getting a response. I.e. it won't accept almost any standard commands.
Why or what do you want to "do" to the standby sup?
Hi Joseph,
The stand-by sup was the active sup-engine which suddenly rebooted. I need to get its show logging.
Jackie
Hi Joseph,
Gab
