how to achieve 40g uplink between Swithces 9600 & 9400
kick534
Please find the attach design,
I need to achieve 40g uplink speed between 9600 and 9400 series switches, from data center switches Cisco 9600 we need to connect three sites, from data center to all sites distance is 400 meters.
Data center : Cisco 9600 series we have line card which support 40/100g
Sites 1,2 &3  : We have Cisco 9400 series modular switch, with line card c9400-lc-24xs  so please explain how we can achieve 40g speed with this. are we can use MPO/MTP.
6 Replies 6
Mark Malone
Those switches don't support straight 40gb
heres what they support exactly https://tmgmatrix.cisco.com/?npid=672
93180s or 92340 support 40/100GB with QSFP uplinks
9600s is not a problem
C9600-LC-24C QSFP-100G-SR4-S 100 Gbps QSFP28 100m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-100G-CWDM4-S 100 Gbps QSFP28 2km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-100G-PSM4-S 100 Gbps QSFP28 500m Ribbon Fiber SMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-100G-LR4-S 100 Gbps QSFP28 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-100G-SM-SR 100 Gbps QSFP28 2km Duplex Fiber SMF LC Optic 10 to 60C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-100G-AOC1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC5M 100 Gbps QSFP28 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC7M 100 Gbps QSFP28 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC10M 100 Gbps QSFP28 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC15M 100 Gbps QSFP28 15m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC20M 100 Gbps QSFP28 20m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC25M 100 Gbps QSFP28 25m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-100G-AOC30M 100 Gbps QSFP28 30m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.11.1
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.11.1
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.11.1
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-SR4 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-SR4 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-CSR4 40 Gbps QSFP+ 300m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-CSR4 40 Gbps QSFP+ 400m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-SR4-S 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-SR4-S 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-SR-BD 40 Gbps QSFP+ 100m (OM3) Duplex Fiber MMF LC Optic 10 to 70C N IOS XE 16.11.1
QSFP-40G-SR-BD 40 Gbps QSFP+ 150m (OM4) Duplex Fiber MMF LC Optic 10 to 70C N IOS XE 16.11.1
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-LR4 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-40G-ER4 40 Gbps QSFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.11.1 IOS XE 16.11.1
WSP-Q40GLR4L 40 Gbps QSFP+ 2km Duplex Fiber SMF LC Optic 10 to 60C Y IOS XE 16.11.1 IOS XE 16.11.1
QSFP-H40G-AOC1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC2M 40 Gbps QSFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC15M 40 Gbps QSFP+ 15m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC20M 40 Gbps QSFP+ 20m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC25M 40 Gbps QSFP+ 25m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-H40G-AOC30M 40 Gbps QSFP+ 30m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.11.1
QSFP-40G-CSR-S 40 Gbps QSFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.11.1
QSFP-40G-CSR-S 40 Gbps QSFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.11.1
C9400
  Transceiver Description Software Release
Network Device Product ID Transceiver Product ID Data Rate Form Factor Reach Cable Type Media Connector Type Transceiver Type Case Temp DOM HW Capable Minimum DOM SW
C9400-LC-24XS GLC-GE-100FX 100 Mbps SFP 2km Duplex Fiber MMF LC Optic 0 to 70C N IOS XE 16.8.1
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-LRM 10 Gbps SFP+ 220m Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-LRM 10 Gbps SFP+ 300m Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-BXD-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-BXU-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-BX40D-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-10G-BX40U-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-H10GB-ACU7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-H10GB-ACU10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-10G-AOC1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-10G-AOC2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-10G-AOC3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.10.1
SFP-10G-AOC5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-10G-AOC7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.6.2
SFP-10G-AOC10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.6.2
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
CWDM-SFP10G-XXXX 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS XE 16.6.2
GLC-TE 10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 16.6.2
GLC-BX-D 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
GLC-BX-U 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-GE-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 16.6.1
GLC-SX-MM-RGD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-LX-SM-RGD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-LX-SM-RGD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-ZX-SM-RGD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
GLC-LH-SMD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
GLC-LH-SMD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
GLC-ZX-SMD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.6.2 IOS XE 16.6.2
CWDM-SFP-XXXX 1 Gbps SFP 100km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
DWDM-SFP-XXXX 1 Gbps SFP 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.6.2 IOS XE 16.6.2
SFP-H10GB-CU1-5M 10 Gbps SFP+ 1.5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.9.1
SFP-H10GB-CU2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.9.1
SFP-H10GB-CU2-5M 10 Gbps SFP+ 2.5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.9.1
Reza Sharifi
The card in the 9400 does not support 40Gig interfaces however the 9400 Sup comes with 2 40Gig interfaces if that is enough ports for you.
hi,
sup line card 40g ports i will use for SVL, and 10g port for DAD,
Please find the attach from data center to each site i have 2 uplinks 40g , but there is no module in 9400 series switch to support 40g , i need to no by using MPO/MTP connections we can get 40g bandwidth
If you can't use the 40Gig ports on the sup to connect to the hub site, than the only thing I can think of is using 4 10Gig in a Portchannel but that means you are using 4 pairs of fiber and not just one. Does that work for you?
Thanks for Reply.
if i use port channel so there is no benefit of putting line card (C9600-LC-24C  - Cisco Catalyst 9600 Series 24-Port 40GE/12-Port 100GE) in 9600 Series Switch, but as our design Required 40 g uplink between DC to all Tower locations.
Hi Sir,
Sorry for late reply,i get your point.
Please conform :
1) For Uplink between Core 9600 line card (C9600-LC-24C) connecting to Hub Switches sup (C9400-SUP-1XL) we can achieve 40G???.
2) between Hub Switches 9400 series to achieve SVL and DAD we can use Line card (C9400-LC-24XS)???.
