How to Add remarks to an existing ACL
Cisco Junky
I am going to be editing an existing extended ACL adding 2 permit lines,(using ACL sequence numbers) but I also want to include remarks.
How do I do this with out having to re-write the entire list, and causing downtime?
You help is much appreciated
9 Replies 9
anoop.verma
Viewing Access Control Lists (ACLs) can be somewhat confusing because the ACLs will all run together. Adding remarks to your ACLs will make them easier to read. When you look at your running-config to view the ACLs without remarks, as shown here:
Switch1#show running-config | include access-list
access-list 50 deny   192.168.8.200
access-list 50 deny   192.168.8.201
access-list 50 permit 192.168.8.0 0.0.0.255
access-list 50 permit 192.168.9.0 0.0.0.255
access-list 60 permit 192.168.8.0 0.0.0.3
access-list 60 deny   192.168.8.0 0.0.0.255
access-list 60 deny   192.168.9.0 0.0.0.255
To make this easier to read, you should start each ACL with a remark line. This does not show up when using the show command; but is in yourrunning-config. This is what it would look like:
access-list 60 remark This ACL is to control the outbound router traffic.
Hi there,
I have an existing ACL
access-list 111 permit ip any host 1.1.1.1
access-list 111 permit ip any host 2.2.2.2
access-list 111 permit ip any host 3.3.3.3
access-list 111 deny ip any any
I want to add a new like to permit host 4.4.4.4 but before have a remark saying Test_4.4.4.4 I cant see syntax to complete this.
I will use the show access-list 111 and then use the spare sequence number between the host 3.3.3.3 and the deny any statement to add the new line, however I cannot add a remark this way.
Any solution?
On which device you are creating acl ?
6509.
I believe the only way is to remove the line "access-list 111 deny ip any any"
add the remark and the new permit statement
Re-enter the line "access-list 111 deny ip any any"
The implicit deny any any will cover this so the ACL will be fully operational at all time?
do you agree
Lets say the spare sequence number is 35
conf t
ip access-list extended 111
35 permit ip any host 4.4.4.4
remark *** TESTING 4.4.4.4 ***
end
However you will not see the remark in show access-list
You need to issue
show run | beg access-list
to see any remarks
Alex
Regards, Alex. Please rate useful posts.
This is not correct... the remark statement will then be placed underneath the "deny any any" statement.
If you place your remark prior to the line with the sequence number, it will show up in the right order.  Your remark should come before the line that you are adding the remark for.  Example:
conf t
end
If you do it that way it should show up in the correct order.
I guess this is long time since your post but THANKS. Everywhere I looked it was always:
1)do new ACL and replace the old one
2)do the lines and then resequence
This needs more recognition!
Hello
example:
sh access-lists
(spare sequence number of 40)
40 permit ?????? etc..
exit
ip access-list resequence 111   10 5
res
Paul
Kind Regards
Paul
