Cisco 9407 Stackwise Virtual - Fast Hello on Copper interface?
shamg1974
I'm attempting to configure fast hello on two copper interfaces on my 9407 chassis' running SVL. It won't give me the option to do so under config mode:
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#int g1/1/0/48
Switch(config-if)#stack
Switch(config-if)#stackw
Switch(config-if)#stack?
% Unrecognized command
Switch(config-if)#stackw?
Is it possible to do this over 1Gb copper? If so, why am I not getting the option. I'm running IOS-XE 16.9.3.
Shameer
Mark Malone
supervisor module only
Fast Hello dual-active detection is supported only on supervisor module ports. Enhanced PAgP dual-active detection is supported on supervisor module ports and line cards.
Mark Malone
