How to allow SSL VPN client to access remote VLAN (RV340)?
LechK
Hello
My VLAN1 config is like below:
192.168.17.1/24
DHCP Server: 192.168.17.100-192.168.17.149
and my SSL VPN pool is:
10.0.0.0/24
How to allow SSL VPN user to access to remote VLAN?
Thanks in advance
LK
5 Replies 5
Reza Sharifi
Not familiar with RV430 but if the clients get IPs in the range of 10.0.0.0/24 from the DHCP server after they login to the SSL-VPN device, than the VPN device needs to perform routing between 10.0.0.0/24 and 192.167.17.0/24 subnet or point to another device that performs the routing task.
Cristian Matei
     If you use split-tuneling, it's a matter of allowing access to 192.168.17.0/24 network. If you use full-tunnelling, there are no requirements, as long as the RV340 can route to 192.168.17.0/24, which is a requirement in the first case as well, anyways. Here's a reference document:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5529-configure-group-policies-on-the-rv34x-series-router.html
Cristian Matei.
Disabled split-tunneling but still I can't ping any other address that 192.168.17.1 (router address) from VPN ;(
Thanks in advancee.
L.
Does the VPN device have a default route or default-gateway towards the router?
Also, the router needs a static route towards the VPM device.
Router provides SSL VPN access. I have no other ACL because they don't work.
While configuring SSL VPN on RV340 router there is no any default gateway or route typed.
LK
EDIT:
I have done some checking and there is something strange.
Looks like I can't ping for example Cisco switch SG-250 (192.168.17.2) and other network hardware like kind of TP-LINK AP with static IP (192.168.17.5) and I can't ping workstations (but it can be because of firewall and I will check it) but I CAN ping other stuff like Hikvision NVR and Cisco SPA112... weird for me. Any idea anyone?
