VLAN's not replicating over VTP
Not applicable
I am introducing a new switch to an existing network, however VLAN's don't appear to be propogating over VTP.
Core Switch - 4506 (192.168.10.1)
New Switch - 3 x 3750's (192.168.10.12)
The two are connected via a trunk:
4506 End:
interface GigabitEthernet2/20
description -- Link to Test Switch --
switchport mode trunk
no logging event link-status
no keepalive
qos trust cos
end
3750 End:
interface GigabitEthernet3/0/1
description -- Link to SW_HH-01 --
end
Both are in the same VTP domain. The 4506 is a VTP server, the 3750 stack is a VTP client. There is no authentication on VTP.
I am able to ping each switch from the other, however still the VLAN's aren't replicating.
Can anybody advise what I may be missing?
Neil
John Blakley
Can you post "sh vtp status" from both switches?
HTH, John *** Please rate all useful posts ***
Peter Paluch
Hello Neil,
I know it's probably almost rude to ask you to redo the verification but double-checking these things usually reveals the discrepancy causing these problems:
  • show vtp status on both switches: make sure that none of them is in VTP Transparent mode. Further on, make sure that the new switch has a lower revision number. Also verify - once again - the VTP domain name. Is the VTP version identical on both switches?
  • show vtp password - make sure that whatever is set, it is set identically on both switches
  • show run | include vtp - make sure that no special VTP configurations are put into either of these switches
Best regards,
Peter
Thanks Peter - I had checked the password on the server, but hadn't bothered on the client. For some reason there was a VTP password set. Even though it only came out of the box a few moments ago...
Cheers,
Neil
