how to apply vlan accesslist in vlan
pratik.kelaiya
Hi Everyone...
Good Afternoon
pls help me how to apply vlan access-list?
Task to apply...
1) VLAN 2 (HOSTEL A), VLAN 3 (HOSTEL B)..ONLY FOR ACCESS FTP SERVER VLAN 6 & ACCESS WEBSERVER (VLAN8)..
2)VLAN4 (STAFF) ONLY FOR ACCESS DNS SERVER (VLAN7). & WEBSERVER (VLAN8)..
3)VLAN5 (LAB VLAN) ONLY FOR ACCESS WEBSERVER (VLAN8)
Simrid123
I would recommend looking at the below link.  It will show you the steps to take along with the syntax of applying a VACL.  One thing I would be sure to investigate is if packet tracer supports VACL.  I know PT can be quite restrictive.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/vlan_acls.html
Dear Sir...
so you say that packet tracer not support to VACL?
so which software is best of cisco pratice?
It's all subjective and down to personal preference; I personally use GNS3.  Another simulation software to look at would be uNetlabs and VIRL.
