min/avg/max = 999999999/858993458/4294967295 ms
pepsico_anz1
just for fun, explain this???!!!
HOCT-LG#ping 10.198.147.150
Sending 5, 100-byte ICMP Echos to 10.198.147.150, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 999999999/858993458/4294967295 ms
oh and it actually replied very quickly, like <10ms WTF?
Sending 5, 100-byte ICMP Echos to 10.198.147.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
glen.grant
We have seen issues like this in the past and its usually a code bug , would check there first for your code version.
thought it would be, just kinda insteresting how it affects some destinations but not others
Just tells me: you can do magic things with software (bugs) ;-)
john.cottingim
I know this is a very old thread. I was unable to find anyone that answered this elsewhere...
This not a software bug as others have suggested. The odd min/avg/max time is caused by the machine that's replying to the echo-request not complying to RFC792 https://tools.ietf.org/html/rfc792.
According to RFC792, "The data received in the echo message must be returned in the echo reply message."
In the case above, the host 10.198.147.150 does reply, but replies with the string: "abcdefghijklmnopqrstuvwabcdefghi" as the data instead of what the Cisco device sent. That string that was being echoed back is typically whats sent from a Windows machine as the data portion of the ICMP Echo-Request packet. However, Cisco does not send that specific string in its echo-request packets.
If you were to do an extended ping and validate the reply data, the Cisco device will show "CCCCC" instead of "!!!!!" indicating that the data received was not the data that was sent.
The odd timing displayed is Cisco's interpretation of the time-stamp that should have been in the reply packet, but was not.
I hope this helps!
JC
