How to automate a shut, no shut in Cisco Switch 2960x
ISE101
I am wondering what the command would be for automating a shut, no shut on Cisco 2960x switches.
I would need to target a few Gi #/#/# ports. Any good tested recommendations?
Depends on why they are being shutdown.
You could use an EEM script to target a specific action or syslog message that appears and run a set of commands based on that, or if its port-security related you should be able to shut no shut the port with either err-disable recovery or using the aging -port-security option I believe
switchport port-security aging time/type
-David
The reason I am manually doing shut and then no shut to bounce the port is to power cycle a POE digital clock.
Clocks seem to loose connection to internal company ntp server and a reboot helps them reconnect and communicate.
Nothing related to security or flapping.
Would you have an idea on commands to use?
Possibly an EEM script using a repetitive timer.
