How to avoid flooding with broadcaste/multicaste frame
sfanayei
Scenario: I would to distribute ghost image from a server in server vlan A to another end devices in same vlan B but in different Cisco switch. Do I have to be aware flooding issue in my network and in the case how can I avoid? Tanks in advance.
sfanayei
6 Replies 6
Giuseppe Larosa
Hello Shanryar,
as explained in this recent thread
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&topicID=.ee71a04&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc2cd67
you need to enable :
ip multicast routing
ip pim sparse-dense mode
on L3 SVI interfaces Vlan A and Vlan B (or router subinterfaces)
on L2 only switches you need to enable ip igmp snooping
verify with
sh ip igmp snooping
if it is enabled on L2 switches
Hope to help
Giuseppe
Hi Giuseppe
Many tanks for your fast reply. Can you tell too that how I can to monitore the process?
I appreciat!
sfanayei
Hello Shanryar,
on the router L3 switch use
sh ip igmp groups
look at the time the group is joined
sh ip mroute multicast-group-address
check that the oilist contains Vlan A and/or Vlan B
on the L2 switch
check if IGMP is enabled with:
sh ip igmp snooping
you can see the multicast addresses in
sh mac-address-table int type x/y
there is a second section after unicast MAC addresses
Hope to help
Giuseppe
Tanks again. It was very useful.
sfanayei
Giuseppe helped me out earlier with that post he recommended, so I'll give him a break and try to answer your question.
You should be able to check that IGMP snooping is active on the switch by typing "sh ip igmp snooping"
This gives you the IGMP snooping global settings as well as individual settings per vlan.
An easy way to check if broadcasts are only forwarded to the ports you want is to use a network sniffer (such as wireshark) on 2 or more systems in the same VLAN.
Start by monitoring both systems without the multicast requestor application running.
Then, on one system, start the application (and hence the multicast requests) - You should see multicast broadcasts only to that system and not the other.
I hope that helps.
Tanks a lot. I will test it like you said.
sfanayei
