how to block HTTPS sites using cisco router
edwarelsayegh
Community Member
i need to block some sites like facebook and youtube
but they use HTTPs
so how i can block them using a policy-map to match those sites
i can match HTTP traffic only but not https traffic
any solution
thanks
17 Replies 17
mattjones03
Level 6
Level 6
Using a policy map to achieve this may not be the best approach.
The ACL will require you to add all the subnets for the site/service you are trying to deny.
Have you considered deploying a proxy solution such as Squid? Really easy to deploy, and free to install if you have available hardware. Once installed you can deny based on the domain name.
Georg Pauwen
here is an example of how to block Facebook:
class-map match-all FACEBOOK
match protocol http host "www.facebook.com"
match protocol secure-http
Hello.
I implemented code bellow:
class-map match-all restricted-sites
policy-map PM-V&V-out
class restricted-sites
  drop
interface dialler 0
service-policy output PM-V&V-out
but users still able to open www.facebook.com
Could you clarify?
What happens if you apply the service policy to the underlying physical interface, that is, the interface configured with 'dial-pool-number 1' ?
I implemented following code at another c891f router connected to provider by cable modem in bridge mode.
  drop
interface GigabitEthernet 8
same results. Connected via that router users still able to browse www.facebook.com
what is the output of:
show ip nbar protocol-discovery
it returned my no output:
gate(config-pmap-c)#do show ip nbar protocol-discovery
but config applied like this:
gate(config-pmap-c)#do sh runn class-map restricted-sites
Building configuration...
Current configuration : 120 bytes
end
gate(config-pmap-c)#do sh runn policy-map PM-V&V-out | s restricted-sites
drop
gate(config-pmap-c)#do sh runn int gi 8 | i PM-
check if you can manually enable NBAR on your GigabitEhernet8 interface:
interface GigabitEthernet8
Which IOS version are you running ?
yep. you are right.
gate(config-pmap-c)#do sh runn int gi8 | i nbar
gate(config-pmap-c)#interface GigabitEthernet8
gate(config-if)#ip nbar protocol-discovery
gate(config-if)#do show ip nbar protocol-discovery
GigabitEthernet8
Last clearing of "show ip nbar protocol-discovery" counters 00:00:16
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
5min Bit Rate (bps) 5min Bit Rate (bps)
5min Max Bit Rate (bps) 5min Max Bit Rate (bps)
ipv6inip 380 149
193144 31974
IOS:
gate(config-if)#do sh ver | i IOS
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.4(3)M9, RELEASE SOFTWARE (fc1)
gate(config-if)#
even after this clients who is going to inet via that router are able to reach www.facebook.com They getting unsupported browser allert but hit site:
# Update Your Browser | Facebook
REFRESH(0 sec): https://www.facebook.com/unsupportedbrowser?_fb_noscript=1
#Facebook alternate alternate
Update Your Browser
You're using a web browser that isn't supported by Facebook.
To get a better experience, go to one of these sites and get the latest version of your preferred browser:
Google Chrome
Mozilla Firefox
Get Facebook on Your Phone
Stay connected anytime, anywhere.
if you don't apply the service policy, do your clients still get the same 'unsupported browser' page ?
yes.
I think they are getting 'unsupported browser' alert because they using lynx browser but I think it doesn't matter because policy applied and ad soon as somebody from internal net it trying to reach www.facebook.com router NBAR has to catch this request and drop it. Right? so results clients will get something like "timeout" but they are getting real page content.
Facebook uses a lot of redirects. Change your class map slightly and see if it works:
match protocol http host "*.facebook.com"
or
class-map match-any restricted-sites
users can reach www.facebook.com using both configuration.
I applied policy to private interface (vlan10) outbout directions:
using this config:
gate(config-cmap)#policy-map PM-V&V-out
gate(config-pmap)#no class restricted-sites
gate(config-pmap)#policy-map restricted-sites4vlan10
gate(config-pmap)# class restricted-sites
gate(config-pmap-c)#  drop
gate(config-pmap-c)#int vlan 10
gate(config-if)#service-policy inp restricted-sites4vlan10
gate(config-if)#
gate(config-if)#
as results:
Vlan10
Last clearing of "show ip nbar protocol-discovery" counters 00:02:50
                            Input                    Output
   youtube                  576                      709
                            69922                    40391771
                            4000                     876000
                            4000                     876000
   ssl                      153                      249
                            16138                    7776438
                            1000                     188000
users still able to hit facebook.com 😞
Hello Andriy,
the Cisco website has the below listed, but I don't think that will work either because of the HTTPS redirection.
class-map match-all facebook
match protocol http host "*facebook.com"
A better option is probably to block the entire IP range used by Facebook, which are listed in the link below. Which country are you in ?
https://ipinfo.io/AS32934
