IP NABAR Not working on subinterface
mrmadgig
Level 3
Level 3
Hello, Hope someone can point me in the right direction here please.
I currently have a situation where I have a simple class-map and policy-map that uses the NBAR IP Discovery protocol ipv4 along with service-policy out on the WAN interface. Below is the config. The issue is that the protocol is filtered on the main LAN interface but not on the subinterface.
Loaded Protocol Pack(s):
Name:                            Advanced Protocol Pack
Version:                         12.0
Publisher:                       Cisco Systems Inc.
NBAR Engine Version:             20
State:                           Active
Cannot seem to figure this out. The end goal was to filter on one interface and not the other. I was going to move the service policy to the LAN subnet interface 172.16.x.x network however doing so discovered it didn't work anyhow.
class-map match-any P2P
match protocol gnutella
match protocol kazaa2
match protocol edonkey
match protocol fasttrack
match protocol winmx
match protocol encrypted-emule
match protocol yahoo-mail
match protocol youtube
policy-map BOCK-P2P
class P2P
drop
Here are the interfaces:
interface GigabitEthernet0/0/0
 description FIBER WAN TO 3850 SWITCH
 ip address dhcp
 ip access-group 100 in
 no ip redirects
 no ip unreachables
 ip nbar protocol-discovery
 ip nat outside
 ip inspect CBAC-FIREWALL out
 ip virtual-reassembly in
 media-type sfp
 no cdp enable
 service-policy output BOCK-P2P
interface GigabitEthernet0/1
 description MAIN_LAN
 ip address 10.10.111.254 255.255.255.0
 ip access-group 125 in
 ip nat inside
 duplex full
 speed 1000
interface GigabitEthernet0/1.1
 description VLAN 2 WIFI
 encapsulation dot1Q 2
 ip address 172.16.100.254 255.255.255.0
 ip access-group 110 in
 ip nat inside
I am not sure if the NBAR works on sub interfaces.
Any help would be greatly appreciated.
Joseph
Ok Tried it and it failed until I addedd this line
match protocol secure-http
It still makes it to the page but will not play the videos.
Added this
MGR2911#sh class-map YOUTUBE
Class Map match-any YOUTUBE (id 3)
Match protocol http host "*youtube.com*"
Match protocol secure-http
Match protocol youtube
Match protocol http host "*googlevideo.com*"
Works great!
11 Replies 11
Francesco Molino
What equipment are you using and which ios?
Nbar should work on sub interface.
Have you applied the nbar? And what issue are you facing?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
HI Thanks fot the reply,
Sorry for the version and missing equipment I know better than that...
2911 C2900-UNIVERSALK9-M), Version 15.5(3)M5
Yes I did apply the NBAR please see the post configs the ip protocol-discovery ipv4  is applied and the service policy on the WAN output
I mentioned in the post that it does not filter the matched protocols in the subibterface. For example anything that is on that interface seems to bypass the service-policy applied. Which in this case is g0/1.1
G0/1 subnet gets filtered.
Thank you
I don't have any 2900 right now but tested on another ISR and it works as expected.
Here my config:
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.239.20.1 255.255.255.0
service-policy output TEST
policy-map TEST
class NBAR
drop
class-map match-any NBAR
match protocol icmp
Here the output of show policy-map int g0/1.20
R1#sh policy-map interface gi0/1.20
Service-policy output: TEST
Class-map: NBAR (match-any)
2 packets, 236 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: protocol icmp
5 minute rate 0 bps
drop
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
You see that the traffic is classified on the right class-map.
Can you share your full config please?
When you apply your policy-map can you share output of show policy-map interf g0/1.1 ?
Also try with a simple class-map like mine (drop icmp) to validate that policy is doing its job correctly.
Francesco
Hello Francesco
Here is the complete config for this section
policy-map BOCK-P2P
 class P2P
  drop
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address dhcp
 ip nbar protocol-discovery ipv4
 ip nat outside
 shutdown
 duplex auto
 speed auto
 no cdp enable
 ip nat inside
 duplex full
 speed 1000
 ip nat inside
interface GigabitEthernet0/1.7
 description RUCKUS VLANPOOL7
 encapsulation dot1Q 7
 ip address 192.168.7.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.8
 description RUCKUS VLANPOOL8
 encapsulation dot1Q 8
 ip address 192.168.8.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.9
 description RUCKUS VLANPOOL9
 encapsulation dot1Q 9
 ip address 192.168.9.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/2
 description ETHERNET WAN INTERFACE
 ip address dhcp
 no ip redirects
 no ip unreachables
 ip nat outside
 shutdown
 duplex auto
 speed auto
 no cdp enable
 ip address dhcp
 no ip redirects
 no ip unreachables
 ip nat outside
 media-type sfp
 no cdp enable
As you can see I didn't place the service policy on the subinterface directly. The result is that it shoulf filter all LAN interfaces and it doesn't. It filters just the NON subs. So I decided to put youtube in there to test if it blocks accesss to youtube.
1. If I am on subnet 10.10.111.0/24 It operates perfectly
2. If I am on subnet 172.16.100.0/24 it does not filter and I CAN surf to youtube.
 3.
interface GigabitEthernet0/2 is shutdown
I will create a another class map and apply it as you suggested and see what happens. In the meantime please let me know if you see any other issue with my config.
Thank you
Joseph
Ok I see now. You're not applying the service-policy to your LAN interfaces, you're applying it on your WAN to filter them.
I'll do a test later when I'll be back to the office.
Francesco
Hi Francesco
I tried to remove the service policy from the WAN and place it just on the subinterface and all my mobile devices can access youtube and facebook. I have samsung devices.
When I put the policy on the Main Lan interface it stops the mobile devices and the PC's.
I was searching today a bit an saw a few posts that say NBAR doesn't work on VLAN and Subinterface.
https://learningnetwork.cisco.com/thread/57835 read a ways down
Also ran into this today when experimenting
MGR2911(config)#int g0/1
MGR2911(config-if)#ip nba
MGR2911(config-if)#ip nbar pro
MGR2911(config-if)#ip nbar protocol-discovery ipv4
MGR2911(config-if)#ip nbar protocol-discovery ipv6
MGR2911(config-if)#serv
MGR2911(config-if)#service-p
MGR2911(config-if)#service-policy out
MGR2911(config-if)#service-policy output BOCK-P2P
Attaching service policy to main and sub-interface or tunnel and sub-interface in the same direction concurrently is not allowed
See error notes on last line
ICMP will most likely work but in production it doesn't
Not sure if NBAR does work on Subs. I cannot find a dininitive answer.
Thank you
Joseph
Don't have any 2911 right now but NBAR2 works on subinterfaces on some platforms.
On this specific one, you need to validate on documentations. I can do some research but give me few days and come back to you soon.
Francesco
Hello Francesco,
Thank you very much. I do have an update. I was doing more troubleshooting by moving the service policy from different interfaces to see the results. I am using the ability to access youtube on mobile devices and PC's and Laptops. Below are my findings.
Under this Subinterface this is the results
 ip nat inside
1. Will Block PC and Mobile devices browser only
   Will not block YouTube App.
2. You need to block these domains. I added them to an OpenDNS
account that I own and nothing at all came through.
   youtube.com
   googlevideo.com
   ytimg.l.google.com
   youtube.l.google.com
   ytimg.com
   youtu.be
   l.google.com
   s.ytimg.com
3. There is no option to match protocol for these.However
you would think that the match protocol youtube would do the
trick. Not so....
4. Adding the following has no affect on the app
 match protocol http url "youtube.l.google.com"
 match protocol http url "googlevideo.com"
 match protocol http url "ytimg.l.google.com"
 match protocol http url "ytimg.com"
 match protocol http url "s.ytimg.com"
 match protocol http url "youtu.be"
 match protocol http url "l.google.com"
So I would say that this does NOT work on subinterfaces well.
Under the Main Interface this is what I find
 ip nat inside
 duplex full
 speed 1000
1. It will block both PC and App with the app visibly
   on the tablet but will not play videos. The videos just spins and timesout.
2. I still believe that these need to blocked too
   for complete blockage. However there is no way that I
   know of without content filtering DNS
   youtube.com
   googlevideo.com
   ytimg.l.google.com
   ytimg.com
   youtu.be
   l.google.com
   s.ytimg.com
So yes and no that is works on subinterface for this model. However that would be awesome if you could find something on the Documents that say something about this model. 2911
Thank you
Joseph
I've done some research and didn't found out any restrictions. You can raise a tac case to be sure.
I've done it on subinterface and it works good.
Instead of url can you use the following command:
class-map match-any YOUTUBE
match protocol http host "*youtube.com*"
Francesco
Hello Francesco
Thanks for the update. I will try that and create the same policy map as you. I have a question though. Did you try youtube appl on mobie device?
Added this
Works great!
