how to Break cisco 2960 switch password without losing configuration
nict
Hi @asharmohammad786
Follow the Password Recovery guide
This won't erase your configuration, but you will bypass it, change the password in the file and reload it with the current config.
Thanks for giving a valuable solution.
You're welcome.
Please rate as helpful and/or solution for others to see if it helped you.
