How to bridge vlan and physical interface on asr?
carensantos23
I will connect a server on g0/0/2 of ASR with IP add 1.1.1.5 and gateway 1.1.1.1. I want that device to be part of vlan 10 on g0/0/0. What configuration should I place on g0/0/2? As much as possible, I dont want to use bridging because I cannot remove the IP address on vlan 10 (it is a production network). Is there any other possible way I can do it?
Current config:
interface GigabitEthernet0/0/0.10
 encapsulation dot1Q 10
 ip address 1.1.1.1 255.255.255.224
 ip flow ingress
 ip flow egress
 interface GigabitEthernet0/0/0.20
 encapsulation dot1Q 20
 ip address 2.2.2.1 255.255.255.224
Any suggestion will be highly appreciated.
Caren
6 Replies 6
Hi ,
 Solution for your requirement is ip unnumbered Command , under your g0/0/2
interface GigabitEthernet0/0/2
ip unnumbered GigabitEthernet0/0/0.10
http://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/13786-20.html
Sandy
Hi Sandy,
        Thanks. The link is up but cannot ping the directly connected device, I use my laptop and the server with the same subnet of 1.1.1.1 for this test. I am using GLC -T on SFP port and the link is 'UP'. On forum, some people say GLC -T works fine and some say it's not (not supported by asr). I ordered SFP -GE -T and will test again.
here's #sh ip int br output:
Gi0/0/0.100            1.1.1.1
GigabitEthernet0/0/2   1.1.1.1   (g0/0/2 inherit the ip of g0/0/0.100)
I tried on gns3 and my lab router 2900 series but encounter this 'Point-to-point (non-multi-access) interfaces only' whenever I configure #ip unnumber... on physical interface.
I am willing to try any other suggestion or solution.
Caren
 To check interface gig 0/0/2 operational status . From your Router Ping to any destination using  source as interface gigabitEtherent 0/0/2 .
Supported T Connector for ASR is SFP-GE-T.
SFP-GE-T
Cisco 1000BASET SFP
The 1000BASE-T SFP module operates on standard Category 5 wiring of up to
328 feet (100 m) link length.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/shared_port_adapters/install_upgrade/ASR1000/asr_sip_spa_hw/ASRsov.html#pgfId-1067788
Sandy
Hi Sandy,
      Thanks.
The new 1000base -T SFP did not even bring the link up, unlike the first one that I used. I inserted the  GLC -T back on g0/0/2, the link went up and do # ping 8.8.8.8 source g0/0/2.
ASR#ping 8.8.8.8 so gigabitEthernet 0/0/2
% Invalid source interface - IP not enabled or interface is down
Gi0/0/0.100            1.1.1.1
Does this mean that the inherited IP by g0/02 from g0/0/0.100 is not valid to work?
Caren
Hi ,
  Are you able to ping from the HOST connected to gig0/0/2 to the gateway IP address 1.1.1.1 .
Share me your router config .
Sandy
I can't ping directly connected device to the 1.1.1.1 eventhough the link is up.
Current config:
 ip flow ingress
 ip flow egress
 ip unnumbered GigabitEthernet0/0/0.100
 negotiation auto
Gi0/0/0.100            1.1.1.1
Caren
