Nexus reset due to major temparature threshold
Arijit Das
Hi all,
I need one help from you .
That is resently on  nexus 5020 switch in my network got reset and logg shows IT IS BEEN RESET DUE TO crossing major temperature sensor threshold..
I need your help to fin out the root cause of this.
Thanks in advance.
Arijit
Reza Sharifi
Is the room, cabinet or closet where the switch is located has enough cooling?  It seems that device got really hot and rebooted because lac of cooling.
Hi Reja,
Thanks for the reply.
Acctually the switch resids in data center where cooing should not be an issue.
Is there any other thing to look after?
Please help.
Arijit
