How to broadcast a message in other networks in cisco packet tracer?
shanoo
I have a very simple network of 5 switches with many PCs connectd to it and a router. I can broadcast a message within a network but cannot do it in all the networks at one time. Can you guide me through the steps to do that?
5 Replies 5
@shanoo
Broadcast does not cross layer3 devices like a router.  As you have a router in the center of your topology, all broadcast will stop there.
As you have a L3 device, and as @Flavio Miranda mentioned the broadcast stops at the router (or the L3 interface it reaches first). If you want to broadcast something across a L3 boundary you'd likely need to implement multicast. Not sure if packet tracer supports those functions but you could try. Make sure you implement it on the router and switches. And any PC that needs to hear the message would need to listen for the IP/MAC mapping of the multicast address you're brodcasting to.
Multicast is a complex and involved technology. It may not be feasible with what you're trying to accomplish either.
-David
Apologies but ip helper can forward broadcast from one network to.other through L3 device.
But I think ip helper command nit support in PKT
MHM
Is it all broadcasts or only DHCP related broadcasts? Even so the OP would have to include an IP helper statement for every PC that needed to receive the broadcast.
Is it all broadcasts or only DHCP related broadcasts? For all
Even so the OP would have to include an IP helper statement for every PC that needed to receive the broadcast. No need he can use limit broadcast to flood to all PC in one subnet' for example 10.0.0.0/24  we can config ip helper with 10.0.0.255
MHM
