How to change Cost/admin distance of static route
Sheraz_35
I have two static routes to the same destination network, they both have admin distance of 1 and cost of 0, what is the command to make one static route more preferred over another static route?
Am I right in saying the cost will need to be modified and not the administrative distance as both routes are from the same routing source? And administrative distance only comes into play when you have routes from different routing sources? Thanks
Steve Fuller
Level 9
Level 9
Correct. To acheive what you're asking simply add the metric to the end of one of the static routes. For example
ip route <destination> <mask> <next_hop_1>
ip route <destination> <mask> <next_hop_2> <metric>
The metric is a value between 1 and 255, with 1 being best and 255 being worst.
