Control Plane, Data Plane and Back Plane
grapevine
Can someone explain me what is Control Plane, Data Plane and Back Plane?
Traian Bratescu
The Backplane represents the internal switch bandwidth (the maximum amunt of data that the switch can handle (internally),
https://supportforums.cisco.com/discussion/10895991/switch-backplane-forwarding-rate-throughput-bandwidth
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/prod_white_paper0900aecd80673385.html
The Control Plane usually refer to packets destined for the router (Routing Protocols - where we move the data / ssh / telnet / snmp, etc)
The data Plane refers to the actual moving of the data.
https://learningnetwork.cisco.com/thread/33735
vaib7av.shirkul
Hi Ranji,
Control plane functions refer to processes that are run in software, whereas data plane functions refer to processes that are run in hardware (ASIC).
For backplane pl check below documents, in very depth explanation.
- HTH
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"Backplane" is a term that goes way back.  It refers to the main chassis hardware into which you insert other cards.  It's the chassis hardware that "glues" together the inserted cards so they can communicate with each other. The backplane, besides providing intercard data communication also generally provides power to the inserted card modules.  So, the backplane generally has control connections, data connections and power connections.  The backplane might being totally passive, i.e. is just provides the wiring between cards, or it might be active, i.e. has some supporting "intelligence".
"Control Plane" and "Data Plane" are logical constructs that address a device's control functions and its data forwarding functions.  In a backplane, as noted above, there are control connections and data connections, but they may share the same physical connections or not.  Also physical connections used to generally run over "buses", and still might, but now there may be multiple buses and/or data connection might run over a "fabric".  In other words, there are lots of variations for hardware, but "Control Plane" and "Data Plane", again, avoid the hardware variations and just consider the logical functions.  Also, "Control Plane" usually addresses a higher level of intelligence than backplane control.
