How to check ALL previous CLI configuration done in switch
TomKeen31000
Hello everyone,,,
How can i check ALL configuration implemented in the switches?
"show archive config differences " didnt see much.
Can i view the config in ID 1,2,3,4,5 below?
KL04SW#show configuration history
1 00:20:50 UTC Tue Sep 24 2019
2 00:20:50 UTC Tue Sep 24 2019
3 00:20:50 UTC Tue Sep 24 2019
4 00:20:51 UTC Tue Sep 24 2019
5 00:20:59 UTC Tue Sep 24 2019
balaji.bandi
What is the model of the switch and what is the version of code.
the only best way i have seen in the real world, from backup config and compare.
BB
if you configure this on your switch:
1. enable
2. configure terminal
3. archive
4. log config
5. logging enable
6. logging size entries
7. hidekeys
8. notify syslog
9. end
and then issue the command:
show archive log config all
all configuration changes will be displayed like below:
Switch#show archive log config all
idx sess user@line Logged command
36 1 console@console | logging enable
37 1 console@console | logging size 1000
38 1 console@console | hidekeys
39 1 console@console | notify syslog
Juni
You can user "show tech-support" command to check all the available configurations in your device.
Please rate helpful.
Thanks.
