How to check CDP Neighbor UPTIME
ALI12
Hello Team,
Does there's anyway to check CDP Neighbor Uptime on :cisco WS-C6506-E
Thanks in Advance
13 Replies 13
Max Jobs
Hi buddy,
Don't hesitate to use this command:
show cdp neighbor detail
Thanks @Max Jobs for your reply,
I used it but not showing the neighbor UpTime
Cdp uptime ? Can you more elaborate.
Uptime of neighbor through cdp?
MHM
yes @MHM Cisco World
that's what I mean ,
Let me check cdp tlv' if there is way to send uptime as cdp tlv.
Update you today
MHM
I have not seen this as a configurable TLV anywhere before. Please do correct me if I am wrong.
See the following documentation: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/cdp/configuration/15-mt/cdp-15-mt-book/nm-cdp-secure-cdp.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
version <<- since we can know uptime by show version then I was thinking using TLV version to get some info from CDP
unfortunately in me lab I can not use this TLV
@ALI12 try if you can use tlv version
if not work then there is no other way
in end there is IP device use as mgmt IP use it to access and do show version
thanks
MHM
Max Jobs
ALI, If you mean timmer or holdtime, here is some commands:
DescriptionCommand
Configure CDP Timer
HQ_Router(config)# cdp timer 100
Configure CDP Holdtime
HQ_Router(config)# cdp holdtime 200
DescriptionCommand
Enter privileged EXEC mode (Enter your password if prompted)
HQ_Router>enable
Display information about neighboring devices
HQ_Router#show cdp neighbors
Display detailed information about neighboring devices
HQ_Router#show cdp neighbors detail
HQ_Router# show cdp entry *
Display IP addresses of each directly connected neighbor
HQ_Router#show cdp entry * protocols
Display IOS version of each directly connected neighbor
HQ_Router# show cdp entry * version
I mean Uptime of neighbor through cdp ,
I think as @Torbjørn reply,  there's no way to see the uptime of a neighboring device
However , thank you @Max Jobs for your reply
Torbjørn
There is unfortunately no way to see the uptime of a neighboring device from CDP directly. That data is simply not included in the CDP frames. You can find the neighbor management IP address with "show cdp neighbor" and log into the device to check uptime with "show version",
Thanks @Torbjørn for this info
ellisfrh13
I'm a bit late to this thread, but show cdp neighbor detail should really have the feature where you can see when a neighbour was last seen over the switches uptime. Very good question that should be looked into as a feature!
For example, I've just come across a work scenario where I wanted to see if a when a cisco AP had last been connected to the port. I know what port it should be on as it was the only one connected to the Wireless VLAN for that switch, and it didn't show up in show power inline so I knew it had been disconnected from it's port. I just wanted to know when it had last been seen. Would be useful as it could have been linked to different problem events that we've been experiencing over the past few weeks.
No, CDP (Cisco Discovery Protocol) does not track neighbor uptime directly on a Cisco WS-C6506-E or any other Cisco device.
CDP primarily provides details about directly connected neighbors, such as device ID, platform, IP address, interface, and capabilities, but it does not include uptime information.
Joshqun Ismayilov
