VPC suspended
amit.sharma
Frequent Visitor
Frequent Visitor
9 Replies 9
Mark Elsen
 - Post exact logs from the devices , for this ; also have a look at https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus9000/101x/troubleshooting/cisco-nexus-9000-nx-os-troubleshooting-guide-101x/m-troubleshooting-vpcs.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Show ip interface breif <<- share this please
MHM
Show vpc breif <<- this also
I need to see from both SW
MHM
I did not take logs of those switches. Can you compare configuration and check any issue in configuration.
You  use PO for keepalive and it config as router port and port member of this PO you dont use no switchport?
Are you sure you can ping via peer-keepalive interface??
MHM
Hello
you vpc cfg looks okay, however you do have inconsistencies of either switch ( see attached file)
Also you could try deleting vpc-peer-link PO2 and defaulting their related ports (eth1/53-54) and then recreate the PC but let it be created automatically.
Kind Regards
Paul
uploaded configuration are in production environment. we are replacing with new switches due to end of life existing switch. i have configure same configuration as old devices configured. what will be issue
Hello
so you need to make sure you have consistency on the vpc
Which you do not have at present -also you are saying the peer-link is down so my suggestion is to re-create is as stated in the file i sent you  and sort out the consistency also shown in that file
Kind Regards
Paul
vishalbhandari
@amit.sharma The issue of the vPC being suspended when connecting the peer link cable is likely due to a mismatch in the configurations on the two Nexus switches. Check that both switches have consistent vPC domain IDs, the same port-channel numbers for the vPC peer link, identical interface settings (speed, duplex, MTU), and matching VLAN configurations. Additionally, ensure the peer-keepalive is properly configured and reachable. Fixing these mismatches should resolve the suspension.
