How to check Flash in Cisco Switch Catalyst 3650
Hi Team Cisco,
In Datasheet Cisco for 3650 Switch for the Flash is 2 GB
The Questions was how to check the flash in Cisco Switch 3650, we already run "show version" and "show file systems".
Here the result for command "show file systems" :
Switch#sh file systems
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
     248354816     247344128      disk     rw   crashinfo:
*   1621966848    1359474688      disk     rw   flash:
           -           -      disk     rw   usbflash0:
             0             0      disk     ro   webui:
           -           -    opaque     rw   system:
           -           -    opaque     rw   tmpsys:
           -           -     nvram     rw   stby-nvram:
           -           -     nvram     rw   stby-rcsf:
           -           -    opaque     rw   null:
           -           -    opaque     ro   tar:
           -           -   network     rw   tftp:
       2097152       2074409     nvram     rw   nvram:
           -           -    opaque     wo   syslog:
           -           -   network     rw   rcp:
           -           -   network     rw   http:
           -           -   network     rw   ftp:
           -           -   network     rw   scp:
           -           -   network     rw   https:
           -           -    opaque     ro   cns:
Assuming value in the command 1621966848 adding 248354816, Totaly 1870321664 bytes. From value Totaly how we to provent it because the value far from 2 GB, any body know. Thanks
rgds,
Aris
Mark Malone
hey all you need is dir , coumnt 6 back in from right gives 1102 mb free
1621966848 bytes total (1102143488 bytes free)
3850A#dir
Directory of flash:/
46466  -rwx     2097152   Nov 7 2015 00:18:54 +00:00  nvram_config
46467  -rwx    74369716   Mar 4 2014 03:32:33 +00:00  cat3k_caa-base.SPA.03.02.03.SE.pkg
46468  -rwx     5808828   Mar 4 2014 03:32:33 +00:00  cat3k_caa-drivers.SPA.03.02.03.SE.pkg
46469  -rwx    32496484   Mar 4 2014 03:32:33 +00:00  cat3k_caa-infra.SPA.03.02.03.SE.pkg
46470  -rwx    30418104   Mar 4 2014 03:32:33 +00:00  cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg
46471  -rwx    16059104   Mar 4 2014 03:32:33 +00:00  cat3k_caa-platform.SPA.03.02.03.SE.pkg
46472  -rwx    64586444   Mar 4 2014 03:32:33 +00:00  cat3k_caa-wcm.SPA.10.0.120.0.pkg
46473  -rwx        1224   Mar 4 2014 03:32:43 +00:00  packages.conf
46474  -rw-         676  Oct 29 2015 15:56:27 +00:00  vlan.dat
46475  -rw-   290796004  Jul 15 2015 07:22:34 +00:00  cat3k_caa-universalk9.SPA.03.06.02a.E.152-2a.E2.bin
77442  drwx        4096  Jul 25 2015 14:14:58 +00:00  dc_profile_dir
Hi Mark,
Yes I already know for the command "dir flash", but actually the questions is the Result of "dir flash" . I Have the same number with you capture were 1621966848 bytes. Were the result "1621966848" same with 2 GB Flash, i dont think so. Because 2 GB convert to bytes mean around the value 1862645149 bytes
Like I said before in beginning post, Is the sum of 1621966848 (flash) and 248354816 (crashinfofiles) became a total flash
rgds,
Aris
Ganesh Hariharan
Hello Aris,
Adding to Mark's comment , Have a look on the below link for more information.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/system_management/configuration_guide/b_sm_3se_3650_cg/b_sm_3se_3650_cg_chapter_010100.html
Hope it Helps..
-GI
Hi Ganesh,
Thanks for the link, Yes I already know the command. But FYI I want to know 2GB Flash convert to bytes were around 1862645149 bytes, but in the real why the value were 1621966848 bytes.
rgds,
Aris
