how to check hardware config of Cisco router/switch
wayne_fan
I need to check the interface card detail of a Cisco router, what command can be used? For Juniper, it's convenient with command "show chassis hardware", what's the Cisco equivalant of this? thanks.
11 Replies 11
ericngimme
sho env
this command doesn't tell me the model details of interface card. I just need to know what kind of interface cards are in each slots. thanks.
How about -
show module [ module-number | fex [ chassis_ID | all ]]
show hardware internal
show hw-module all
switch# show module
Mod Ports Module-Type Model Status
1 40 40x10GE/Supervisor N5K-C5020P-BF-SUP active *
2 6 6x10GE Ethernet Module N5K-M1600 ok
3 8 8x1/2/4G FC Module N5K-M1008 ok
Mod Sw Hw World-Wide-Name(s) (WWN)
1 4.2(1)N2(1) 1.3 --
2 4.2(1)N2(1) 0.100 --
3 4.2(1)N2(1) 0.200 20:81:00:0d:ec:e7:df:40 to 20:88:00:0d:ec:e7:df:40
Mod MAC-Address(es) Serial-Num
1 000d.ece7.df48 to 000d.ece7.df6f JAF1344BHNK
2 000d.ece7.df70 to 000d.ece7.df77 JAB1228018M
3 000d.ece7.df78 to 000d.ece7.df7f JAB1231020C
switch#
switch# show module 2
switch#
Farrukh Haroon
show diag
Farrukh
vaisharm
'show diag' is the command.
~Vaibhav
ropethic
Level 4
Level 4
show hardware
smohanasundaram
try "show Version" command,
regs
S.Mohan
ssaarinen74
For IOS devices I would say
show module
For CATOS
show ver
mikeleebrla
"show inventory" should tell you what you are looking for
Hi Friends,
For checking the device hardware config, we can use
#show version
#show diag
#show inventory
Share if anyone know more commands. Bye Now.
Have a good day . . .
sh inv
sh ver
both work on my 2960-x
