PBR with recursive next hop in 16.12.1 release
RameshPVN8915
On the Catalyst 9300s I am trying to make PBR with ECMP work using the recursive next-hop path. With earlier software releases - when I configure a route-map which has recursive next-hop - I would get a syslog saying its not supported. With 16.12.1 - I do not see the syslog and show running config does show that its configured on the interface. However - traffic does not seem to work - either with ECMP or without ECMP. Traffic is getting blackholed. If I change it to single regular next hop, it does work again.
My question is - is PBR recursive next hop on Catalyst 9300 - supported or not ?
Hello
Can you post the route map and any related acl config - also can you confirm what interface you are appling this policy to?
Kind Regards
Paul
