how to check if devices are on same network or not?
mahesh18
Level 6
Level 6
i have one host IP
172.16.10.100/16 and another host
172.16.20.200/24
how can we check that if they are in same network or not?
many thanks
mahesh
20 Replies 20
The OP never asked about configuration in a router.
That's the problem with us techies, we just think about if the router supports the commands and we end up failing on those tricky questions during the exam :)
I've been burned many times assuming just that and now read the questions differently.
I have a feeling the OP saw this question in a Cisco exam :)
__
Edison.
royalblues
Level 10
Level 10
use any online subnet calculator
http://jodies.de/ipcalc
Narayan
Edison Ortiz
The host 172.16.10.100 255.255.0.0 is on the same network as 172.16.20.200 255.255.255.0 but 172.16.20.200 255.255.255.0 is not in the same network as 172.16.10.100 255.255.0.0 - thus you will have connectivity issues between these devices as the path from one device to another may be different.
__
Edison.
Edison,
I think you put it the reverse way
The address 172.16.20.200/24 is on the same network as 172.16.10.100/16
Narayan
Hi ediortiz,
can u please explain me in more detail
many thanks
mahesh
hi mahesh
your network
172.16.10.100/16
network 172.16.0.0
first host 172.16.0.1
Last host 172.16.255.254
broadcast address 172.16.255.255
next network 172.17.0.0
So your network 172.16.20.200/24 and 172.16.10.100/16 are host 172.16.0.0/16 network
