how to check packet loss on router
I have to determine if packets are being lost between my IP cisco phones on one site to the call manager on other site through my cisco router.  What do I I do on the router to see if packets are being lost?
Thanks.
Scott Brien
show interface if_type
  Input queue: 0/2000/20408/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 293000 bits/sec, 128 packets/sec
  5 minute output rate 989000 bits/sec, 148 packets/sec
     1247270683 packets input, 1721112099278 bytes, 0 no buffer
     Received 6485788 broadcasts (436942 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     825292982 packets output, 184712093707 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
6 Replies 6
Scott Brien
Hi Horacio,
The above show interface will give you only total output drops: 0
If you want to see packet loss between one end and other end you need to use any tool which provide you the network latency and packet loss.
Also you can run the below script which provide you the latency and packet drops.
Rune the below script from yoru one site to call manager which is at other site.
:22
ping *callmanagerip* -n 120 >>callmanagerip.txt
echo. |time >>callmanagerip.txt
goto 22
Please rate the helpful posts.
Naidu.
Naidu,
     Could you pls explain the script,
:22
goto 22
What does this 22 means?
the :22 is a label
the GOTO 22 will tell the script to go to label 22 so with this script it will reach the GOTO 22 and jump back to the top and repeat over and over.
Sukanta Biswas
You can try what others are suggested. But extended ping with 50 to 100 repeat count and 500 or 1000 datagram size and  would be a good test from router interface to your voice vlan. This would give you if there is any packet drops marked as dot(.)
Hope this helps
Please rate accordingly if it is helpful.
Sukanta
Hi Horacio,
When you run the script, it will do continues ping to your callmanagerip and get the output details in to notepad as "callmanagerip.txt
So that you can get to know the latency and packetloss to your callmanger.
Naidu.
