How to check serial numbers from CLI
PakistanMNP
Dear All,
Kindly share your experiences regarding how can I check the serial number of power supply of cisco 2960s  via CLI ?
show inventory and show version do not show desired information.
PakistanMNP
Finally I got the information
show version command shows the power supply serial number.
7 Replies 7
Deepak Kumar
Please check with "show inventory" command.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
There is no way to determine what is the serial number of the power supply remotely.
PakistanMNP
I don't see a serial number in the show version output ...
FIREPOWER-A# sho version detail
FPRM:
Running-Vers: 4.2(2.15)
Package-Vers: 2.2(2.17)
Activate-Status: Ready
Startup-Vers: 4.2(2.15)
FIREPOWER
This works for me:
connect ftd
system support diagnostic-cli
show chassis detail
Please use the below especially if you are trying to look the serial numbers on switch stack
sh version | inc System Serial Number
Perarivalan C
Use the cmd
Rtr1#sh licence udi
Perarivalan C
Network and Security Engineer
+91 9597581464
