Ethernet channel on 02 switch 2960S
Dear Team.
I have two switch 2960, WS-C2960S-24TS-L and WS-C2960S-48TS-L was stackable.
I was configured ethernet-channel, using one port on 2960S-24 port and other port on 2960S-48 port but not success.
After enter command channel-group 1 mode auto,
switch show error that it need two port belong to the same a switch.
Please help me solution?
Thanks.
2 Accepted Solutions
Nam,
Try this
int gi1/0/1
channel-protocol lacp
channel-group 1 mode Active
on other port
int gi2/0/1
regards
Inayath
As I indicated before, PAgP does not support cross-stack etherchannel.
You are using PAgP with the 'auto' option.
Change the 'auto' option with 'passive' for LACP implementation.
7 Replies 7
InayathUlla Sharieff
Nam,
Few things I believe you have already checked:
1- Phycial interface is up
2- Before the etherchannel the port is up if directly connected between two switches.
3- Can you configure to use channel protocol or force that to on.
4- Give us the output of show etherchannel summary
Inayath
Dear Team.
Yes, physical interface up.
On Stackable switch:
interface gi1/0/1
interface gi2/0/1
Stackable switch show error output, that it need port belong to the same a switch.
Thanks.
Edison Ortiz
Per documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/15.0_2_se/configuration/guide/swethchl.html
You can use PAgP only in single-switch EtherChannel configurations; PAgP cannot be enabled on cross-stack EtherChannels. "
Use LACP instead.
Dear Edison Ortiz.
It's mean, i need add more command below:
int gi1/0/1
on other port
int gi2/0/1
Thanks.
Nam,
Try this
int gi1/0/1
on other port
int gi2/0/1
regards
Inayath
Good solution.
Thanks Edison and Inayath.
