How to config an IP address to a port in switch 4507R-E
ssnickson
I m very new to networking line. I have Cisco 4507R-E as core switch and i have connected to the console to do my intial setup. I have 1 24 port module at 1st slot. I would like to know how to config a IP address to the port? . I have 2 Cisco IP Phone connected to the switch. Need to set the IP for these two IP Phone and need to ping and try the connection. I need it very urgently.Thanks in advance
9 Replies 9
Jon Marshall
With a L3 switch you don't actually assign IP's to ports usually. What you do is to create a vlan and then assign the phones into that vlan so assuming your subnet for the vlan is 192.168.5.0/24
4500(config)# vlan 10
4500(config)# int vlan 10
4500(config-if)# ip address 192.168.5.1 255.255.255.0
4500(config)# no shut
then on the 2 ports for the ip phones -
int gi0/1
switchport
switchport mode access
switchport access vlan 10
spanning-tree portfast
then you allocate an IP address of the 192.168.5.0/24 network to each phone.
Jon
Hi marshall,
THanks for your reply. I have tried the command you have advice
i can set the vlan but when i try to set the ip address for a particular port. I doest allow me to enter 0/1. it always says  % Invalid input detected at marker
and the marker is at 0. What could be the possible error
If the module is in slot 1, then try interface gig/fast 1/?
If the port is L2, then you cannot assign an IP address. Like  Jon mentioned, assign the port to a VLAN
For
"If the module is in slot 1, then try interface gig/fast 1/?
If the port is L2, then you cannot assign an IP address. Like  Jon mentioned, assign the port to a VLAN"
The module is actually in slot 1
i tried using gi0/1 and fast0/1 but it still gives me the same error
when i try help with ?
under gi ?
it only show <1-7>
Use 1/0 1/1 etc, not 0/0 or 0/1
ssnickson wrote:
Hi marshall,
Why are you trying to assign an IP to the port ??
Assign an IP to the vlan interface as described and then assign IPs to the phones. If you assign an IP to the port this will not mean that the IP phone has that IP. You need to configure the actual phone with an IP or setup DHCP.
Jon
Hi Marshall,
Meaning to say that ip phone IP address has to be within the VLAN IP range ?
ok my IP Phone Address are
10.10.12.3 and 10.10.12.2 (Default when we connect)
I set the VLAN as 10.10.12.0
So do i need to do anything on the IP Phone ?
or need to do setting in the switch?
ssnickson wrote:
Hi Marshall,
You don't need to config anything on a switch. You need to either config the phone itself to have a static IP or you need to seup DHCP so the phone can get an address. The phone should have interface that allows you to set the IP or tell it to use DHCP.
Jon
markiy071384
You might consider this. Just issue a "no switchport " I did this on layer 3 switch. And it will not work on layer 2 switch.
Here is the sample.
Switch(config)#int giga2/0/1
Switch(config)#no switchport
Switch(config)#ip address 10.1.1.1 255.255.255.0
You can see also the sample command on this website.
https://www.networkpointview.com/2018/10/intervlan-routing-on-layer-3-cisco.html
