How to configure a port on a vPC Peer (Not member or orphan port)
rumak18
i know how to configure orphan Ports (Device with a single connection to a vPC Peer) and how to configure a vPC member Port (Down stream device with Port-Channel to both vPC Peers).
But what about devices that use several connecton. For exmaple :
A) a firewall with a FHRD (Active Passve) configuration
or
B)a server with several NICs
or
C) just a switch that has not configured Port-Channel on two connection (So only RSTP will block one connection).
I guess this is neither a vPC member nor a orphan port configuration. But i am absolutely unsure.
Mark Elsen
  - In that case the VPC Peer makes no difference for devices with multiple links and need to be looked at as 'one single switch entity'
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
rumak18
Sure, but how should i configure the ports on the vpc Peers in this cases? As "orphan Ports"? As "vpc member" or just as a "Access Port" (alternatively Trunk Port) ?
           - That depends on the capabilities and needs of the connecting host.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
