no ip dhcp snooping trust not working
hfakoor222
Doing a lab
PC1 and PC2 wont get DHCP address if I have
"no ip dhcp snooping trust"  configured on e0/1  and e0/3
as soon as I configure ip dhcp snooping trust  they get addresses from the server
however this defeats the purpose of the lab and the dhcp snooping trust feature
Any ideas?
I'm thinking an IOS bug in GNS3,  not sure.
hostname IOU2
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ip icmp rate-limit unreachable
ip dhcp snooping vlan 1-2084
no ip dhcp snooping verify mac-address
ip dhcp snooping
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Ethernet0/0
switchport trunk native vlan 100
switchport mode trunk
switchport nonegotiate
ip arp inspection trust
interface Ethernet0/1
switchport access vlan 210
switchport mode access
ip dhcp snooping limit rate 100
ip dhcp snooping information option allow-untrusted
interface Ethernet0/2
no switchport
ip address dhcp
duplex auto
interface Ethernet0/3
switchport access vlan 220
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
when i switch these to
the PC gets an address....
Martin L
What is your image version?  This might be your IOL image bug, its limitation or lack of this feature.  Note that not all features are supported in those virtual images even thou the command works.  as I recall, 2nd release of Iron IOL image supported dhcp snooping.
Regards, ML
**Please Rate All Helpful Responses **
balaji.bandi
For the access port wherer the end device connected you do not need dhcp snooping config.
you can configure globally.
check below guidance :
https://study-ccna.com/dhcp-snooping/
https://www.cisco.com/c/en/us/support/docs/ip/dynamic-host-configuration-protocol-dhcp-dhcpv6/217055-operate-and-troubleshoot-dhcp-snooping.html
BB
