how to configure bgp/static for policy route
julxu
I need to configure a policy route as,
that if traffic from xxx.xxx.xx.0/24 to yyy.yyy.yyy.0/24 than route it to vpn box xxx.xxx.1.10
if traffic from xxx.xxx.1.10 to yyy.yyy.yyy.0/24 go to default route 0.0.0.0
I believe it is ok to ach using route map, am I right? if so, could I get advice how to setup?
Any comments will be appreciated
thanks in advance
julxu
8 Replies 8
Cisco Freak
Level 4
Level 4
You can achieve this with the help of policy based routing(PBR) in the router.
CF
thanks for the reply, please advice the tip? how to do it?
Please share more about your configuration to give exact config details.
This link clearly explains the steps involved in it:
https://glennmatthys.wordpress.com/2012/04/24/policy-based-routing-example-route-one-subnet-via-isp-a-and-another-via-isp-b/
CF
Hi Freak
my case is:
  asr1004 import a default route 0.0.0.0 from int 0 with bgp neibour address 10.100.100.100
assume internal traffic 10.10.0.0/16 coming into asr1004 on int 1 with ip address 10.3.3.3
assume vpn with ip address 10.10.2.2 is direct linked to asr1004 int 2, and int 2 ip address is 10.10.2.1
assume taget network is 10.200.200.0/24
I want internal traffic (10.10.0.0/16) go to target (10.200.200.0/24)  to be redirect to10.10.2.2 (vpn)  first, so I add  "ip route 10.200.200.0/24 10.10.2.2" on asr1004.
Than, I want vpn (10.10.2.2) encrypt traffic and send it to one of ip in10.200.200.0/24 range again. at this point if I put local policy route-map below, is it will work?
ip local policy route-map vpn-out
access-list 100 permit ip 10.10.2.2 any
route-map vpn-out permit 10
  match ip address 100
  set ip next-hop 10.100.100.100
interface TenGigabitEthernet0/0/0
 description bgp to get default
 ip address 10.100.100.100 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
interface TenGigabitEthernet0/1/0
 description get internaltraffic
 ip address 10.3.3.3 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
interface GigabitEthernet0/2/1
 description vpn
 ip address 10.10.2.1 255.255.255.248
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 media-type rj45
 negotiation auto
Please advice if it is correct one?
I am sorry..I am not able to understand your network setup. :(
I see that the traffic is router to 10.10.2.2 from the ASR. So if you want to encrypt the traffic from there, do you have required VPN configs there?
Also, why are you configuring the local policy-map. The traffic is NOT initiated from this router, so we will NOT need a local policy map. Local policy map is applied to affect the traffic initiated from that device itself.
Also, why the next-hop is set to an interface IP 10.100.100.100 within that device itself?
the vpn has only one interface.
and currently it setup as:
     if to go 10.200.200.0/24 go to 10.10.2.1
     if to go  10.10.0.0/16 go to 10.10.2.1 also.
so this leave me no room to setup static route.
for example:if my pc has ip 10.10.50.50, and I access the 10.200.200.50, the traffic will come to asr1004 int te0/10, and since I have default route there so it go to 10.10.2.2 (ip route 10.200.200.0/24 10.10.2.2). the vpn encrpt the traffic and it sent it back to asr1004. with same destnation, than the asr1004 resend the traffic back to vpn box .....
 if I have another router to make vpn in middle, than, there will be no problem, but, I have only one router, not two. so I guess if it is possible to do PBR?
if not local one, can I do below:
int te0/1/0 (for internal traffic)
ip policy route-map redirect-to-vpn
route-map match-vpn-traffic
  match ip address to-target
  set ip net-hop 10.10.2.1
access-list extend  to-target permit 10.10.0.0 255.255.0.0 10.200.200.0 255.255.0.0
if it is still not a right one? please advice what I should do to correct this issue.
What is the VPN box? Does it have a outbound connectivity towards 10.200.200.0/24. Or the only way is via ASR?
How is the VPN config there? Who is the other end VPN peer?
CF
it only connect to ASR, and it has only one interface.
I have only know the vpn do not use routing protocol, so I guess it is static route configure for only two direction. one to internet and one to internal.
I think it expect I have two routers, which one is FW for internal and one for border.
and they expect the FW will use static router to redirect  traffic to it,
but our FW do not doing routing also, it also only static setup.. that left only one box (border router) doing routing.
or there is any other way?
