How to configure cross VRF routing (route leak) in Nexus devices?
Steve Rodrigue
I try to configure a simple setup (2 vrf with loopback interfaces that would be see each other). I'm hitting a "wall", because I can't set an RD in my VRF context. Here a reference to an old discussion in this community about this subject.
The final goal/objective is to leak some route between a VRF and the global routing table. I mention it, because it may require special attention and/or features.
My setup:
Nexus 6001 chassis running 7.1(0).
License LAN_ENTERPRISE_SERVICES_PKG = In Use.
Feature bgp is enabled.
Do I need to enable another package/feature?
(In the feature list, I don't see anything related to MPLS).
NOTE: I'm familiar with VRF, but on ASR and other small routers environment. So, I don't need "basic explanation". I know what config I have to put in the Nexus, but I can't. :'(
Amit Goyal
Hi Steve,
Saw the old discussion which has covered most of the options.
>Do you have an option of connecting a physical cable locally on the Nexus device? Two interfaces should belongs to different VRFs as per below.
      Nexus
|          VRF A +-----+
|                |IGP  |Local
|                |     |Loop Cable
|          VRF B +-----+
> Run an IGP (OSPF/EIGRP etc) over this physical path and try advertising routes between two VRFs as per your requirement.
See if it helps.
-Amit
I surely tough about this solution. But we don't like it, it is not "elegant" and counter-intuitive. I'm exploring PBR. I also found out the Nexus 6000 does not seems to behave like Nexus 7000 which I also have access to.
