Access each other between 2 vlan on switch layer 3 ( 3750)
pvhoait01
Hi Everyone
Can someone help me to fix my issue?
i have configured 2 VLAN on same switch 3750 as below ( i have configured routing between 2 vlan), i need only allow pc1 (172.16.1.1) access www server 1(192.168.1.1) and pc2( 192.168.1.2) access telnet server 2( 172.16.1.2). how can i do that?
vlan2: 192.168.1.0/24
vlan3: 172.16.1.0/24
Thank You
Hoa
6 Replies 6
Terence Payet
This can be done using the below ACL:
ip access-list extended VLAN3_VLAN2_WWW
 permit tcp host 172.16.1.1 host 192.168.1.1 eq 80
 deny tcp 172.16.1.0 0.0.255 any
 permit ip any any
ip access-list extended VLAN2_VLAN3_TELNET
 permit tcp host 192.168.1.2 host 172.16.1.2 eq 23
 deny tcp 192.168.1.0 0.0.255 any
 permit ip any any
int vlan 2
ip access-group VLAN3_VLAN2_WWW in
int vlan 3
ip access-group VLAN2_VLAN3_TELNET in
HTH.
Please rate helpful post.
Terence
Thank Terence for your Answer.
i have done as your suggestion but after that not ONLY the protocol WWW or Telnet, the other service also enable each other.
can you help me this?
thank
I dont understand. Are you saying that it is not working? As in everything is being allowed despite the ACL.
Terence
Hi Terance,
I think your acl traffic flow direction is wrong. Either you can swap the acl on both vlan or you can change the acl direction.
#####Option1
int vlan 2
ip access-group VLAN2_VLAN3_WWW in
int vlan 3
ip access-group VLAN3_VLAN2_TELNET in
##### Option 2
int vlan 2
ip access-group VLAN3_VLAN2_WWW out
int vlan 3
ip access-group VLAN2_VLAN3_TELNET out
Hi Terence
as i say, i need ONLY allow pc1 (172.16.1.1) access www server 1(192.168.1.1) but i found that the other pc froom vlan 3 (172.16.1.2) also access www server 1(192.168.1.1) as attached1.
i also need ONLY pc2( 192.168.1.2) access telnet server 2( 172.16.1.2). but pc1(192.168.1.1) also telnet to server 2(172.16.1.2) as attached2.
kindly help please
Hoa
As explain by pawan.raut.
I made a mistake in the ACL flow.
Please apply the following instead:
int vlan 2
int vlan 3
HTH.
Terence
