How to do Vlan Bridging ( for specific vlan traffic )
mithun_raam
Hi Team,
I have a requirement to do vlan bridging. That is My core switch has vlan 101, which connects to the MPLS router. And users from branch officer reach HQ via MPLS -> Core Switch.
And server segments-1 is located under vlan 105. ans server segment-2 is located under van 110.
I need to install traffic optimizer ( RIverbed Steelhead ) to optimize some filtered user traffic, whic his sent for server segment-2. Using vlanl bridging. ( Riverbed also will be connected to the core switch.
that is say user source ip : 192.168.114.0/24 , server segment-2 : 192.168.101.160/29
I want your help to know,
1. How vlan bridging works and how to configure ?
2. Can we filter specific source & destination address based traffic only to be bridged to riverbed ?
thank you.
MIthun R
can you post a schematic drawing of your current setup, and indicate what you are trying to achieve ?
Hello
it seems to me that you need inpath RB so I t connects between you lan and wan rtr.
so to do this  you:
1)connect the lan Interface from  your wan rtr into the RB lan port -(normal straight through cable)
2) connect crossover cable from RB wan port into wan rtr
3) connect the a RB mgt primary port into access port(your mgt vlan)  of switch  So you can admin the RB remotely
res
paul
Kind Regards
Paul
Hello
Also here is the RB support URL so you can review other setups
https://support.riverbed.com/bin/support/static/ei2rup2l0fegpmr2sgjt1cggc4/html/7kdai6aul199rc1crcghv0l4tp/sh_cx_9.6_icg_html/index.html#page/sh_cx_9.6_icg/install.html
Res
Paul
Kind Regards
Paul
