how to configure inter vlan routing
TangoAlfa
I have a cisco L3 switch and two L2-2950 switch how to configure Inter Vlan Routing between them? plz help me to do this
   You just configure L3 switch to act as gateways of all VLANs you want then turn on "ip routing" on it. You just configure trunk interfaces to connect between L2-2950 to connect to L3 switch. Don't forget to add vlan on all switches or use VTP to do so.
HTH,
Toshi
Hello Tanmay,
maybe this link will help you:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Have a nice day,
Dmitry
fb_webuser
Level 6
Level 6
To configure inter vilan routing between the two switch,configure sub-interface from the routers interface mode and then issue encapsulation dot1q
Posted by WebUser Kenechukwu Ogbu
