How to configure L2 logical connections between Cisco 3750x and ASA 5525x
blue phoenix
Hi all,
My client has a Sonic Wall Firewall and I need to replace it with an ASA with Failover design.
Kicker:
The 3750x is doing the inter-VLAN routing currently and has a default route (ip route 0.0.0.0 0.0.0.0) going to the Sonic Wall
They have a proxy-server so, my assumption is that there is a return route to the proxy-server and the next hop is the 3750x.  The only IP that is NAT'd is the proxy-server IP...
WHAT I AM GOING TO DO:
I will use 8 interfaces on the 3750x and JUST USE 1 port-channel5; Connecting 4 interfaces to ACTIVE ASA, and 4 interfaces to SECONDARY ASA.
! PORT-CHANNEL CONFIGURATION ON THE 3750 WILL BE:
int range g1/0/2-5
 description TO ACTIVE ASA
 switchport mode trunk
 switchport trunk encap dot1q
 switchport trunk allowed vlan x,y,z
 channel-group 5 mode active
interface range g2/0/2-5
 description to SECONDARY ASA
interface Vlan600
 description TO ACTIVE AND SECONDARY ASA CONNECTION
 ip address 10.136.255.233 255.255.255.248
 standby 1 ip 10.136.255.235
 standby 1 priority 110
 standby 1 preempt
 standby 1 authentication md5 key-string 7 aaa
 standby 1 track 1 decrement 30
track 1 interface port-channel 5 line-protocol
! IS THIS THE CORRECT NEXT HOP???
ip route 0.0.0.0 0.0.0.0 10.136.255.236
! PORT CHANNEL CONFIGURATION ON ASA WILL BE:
interface range Gi0/1-4
 speed 1000
 duplex full
 lacp port-priority 32768
 no  flowcontrol send on
 no nameif
 no security-level
 no ip address
port-channel 5.600
 lacp max-bundle 8
 port-channel min-bundle 1
 no port-channel span-cluster
 vlan 600
 ip address 10.136.255.236 255.255.255.248 standby 10.136.255.237
 description Runcorn Comms
 security-level 100
 speed 1000
 duplex full
 port load-balance src-dst-ip
Question 1:
Is this the right design implementation or is there a better way?  If there is kindly point me to a document since all the Cisco documents seems to be isolated to hardware and no integration design for several platforms....
Do I need to use port-channel5 to connect to ACTIVE ASA, and port-channel6 to SECONDARY ASA?,  In Cisco document, it says to use 2 different port channels connecting to a switch that is in VSS mode.  My 3750 is just stacked... and it is just 1 switch with one IP address for management, no virtual switch.  So does that mean I can use only 1 port-channel5?  No need to create a port-channel 6 ?
Question 2:
In HSRP, you have 2 physical interfaces on the 2 devices and 1 virtual IP and a virtual mac-address, that way when the primary router dies, users will not feel it since it is pointing to a virtual IP and mac-address.  In the 3750, when I create a default route going to the ASA, do I just use the IP of the ACTIVE ASA?  Do I need to configure a virtual mac-address and can someone point me to a simple doc that will do that?
Please let me know if you need more details and I will try to provide.
18 Replies 18
Question 1:
You have to configure two port-channels, one for each ASA. With only one channel, traffic would flow also to the standby ASA which couldn't handle that traffic.
Question 2:
ASA failover works completely different then HSRP. The IP and MAC that is used on the active ASA is used for the communication with the rest of the network. In the event of a failover, the addresses are shaped between the active and standby ASA. You connected devices still use the same IP as the default-gateway and nothing changes in the ARP-caches. Only the mac-address has to be learned on a different port. For that the ASA sends a gracious ARP to the neighbors.
@Karsten Iwen
If I configure 2 port-channels, I need another subnet which means I need to ask the client to give me one.
Does that mean I will have 2 static routes?
1 pointing to port-channel5
1 pointing to port-channel6
Please clarify... and thanks for the quick response.
No, you don't need an additional subnet. Both channels *have to* share the same subnet for failover to work.
The network-design is completely independent of the fact that you want to use a channel. Normally you have one link from the primary ASA to your switch and one link from the secondary ASA. Now you just replace the single link with a channel.
@Karsten Iwen
I am a little bit confused on the setup you are recommending...
2 port-channels but only 1 IP subnet on the 3750x?  I configured an IP subnet since it needs to communicate with the ASA on the same subnet.  The port-channels are trunk links on the 3750x side as you can see in the configs.
Could you please help to clarify by sending sample configs
You need one IP subnet per logical firewall interface. If all your internal VLANs are terminated at the core, then you only have a single transfer network as in your config, but with two channels. You would only allow your vlan 600. Just be aware that your port-channel is a layer 2 interface and doesn't have an IP-subnet by itself.
Now let's assume you want to terminate your guest-vlan (999) at the firewall.
You just add the vlan 999 to the allowed vlan-list and configure an additional subinterface on your ASA.
ok, so all my internal vlans are in the 3750x
! SWITCH CONFIG
I will create L2 port-channels 5 and 6 connecting to ASA-STANDBY and ASA-ACTIVE respectively and they are trunk dot1q.
! I will only allow vlans that are in the 3750x?
I will have SVI for vlan600 which is the FW interconnect from the 3750x to the ASAs, I will allow also vlan600 in the trunk
! FIREWALL CONFIG
I will configure interface portchannel 5.600
I will configure an ip address the same subnet as the SVI for vlan600 in the 3750x switch
! WHAT WILL HAPPEN TO portchannel6? WHAT IS IT'S IP ADDRESS?
The Trunk only needs the transfer-clan 600 because all other plans are routed on the 3750.
On the 3750 you have two port-channels. On the ASA, there is only one channel configured that is used on both the active and the standby ASA.
So just to confirm if I got you right.
!SWITCH CONFIG
interface range Gi1/0/2-5
 description to ASA-STANDBY
 switchport trunk allowed vlan 2,3,52,200,600
interface range Gi2/0/2-5
 description to ASA-PRIMARY
 channel-group 6 mode active
interface Vlan600
 description FW_interconnect
 standby 1 preempt
 standby 1 authentication md5 key-string 7 ASA
!FIREWALL CONFIG
Port-channel 5.2
 lacp max-bundle 8
 vlan 2
 ip address 10.0.5.1 255.255.255.0 standby 10.0.50.2
 description LAN1
 security-level 100
 speed 1000
 duplex full
Port-channel 5.3
 lacp max-bundle 8
 vlan 3
 ip address 3.0.0.157 255.0.0.0 standby 3.0.0.158
 description Legacy LAN2
 security-level 100
 speed 1000
 duplex full
Port-channel 5.52
 lacp max-bundle 8
 vlan 52
 ip address 10.0.52.1 255.255.255.0 standby 10.0.52.2
 description LAN3
 security-level 100
 speed 1000
 duplex full
port-channel 5.200
 lacp max-bundle 8
 vlan 200
 ip address 10.136.1.254 255.255.255.0 standby 10.136.1.253
 description LAN4
 security-level 100
 speed 1000
 duplex full
port-channel 5.600
 lacp max-bundle 8
 vlan 600
 description FIREWALL INTERCONNECT
 security-level 100
 speed 1000
 duplex full
 speed 1000
 duplex full
 no nameif
 no security-level
 no ip address
ip route LAN1 255.255.255.0 10.136.255.235
ip route LAN2 255.255.255.0 10.136.255.235
ip route LAN3 255.255.255.0 10.136.255.235
ip route LAN4 255.255.255.0 10.136.255.235
ip route 0.0.0.0 0.0.0.0 [PUBLIC IP TO INTERNET ROUTER]
On your original post you mention that the 3750 is doing the vlan-routing. Now you have your VLANs on the ASA (and additionally routes to the 3750) ... What do you really want?
And there are no "nameif" commands on your subinterfaces which are needed.
Sorry for that confusion.  Initially the interVLAN routing is on the 3750x for the internal vlans.  The Sonic Wall Firewall is the default route going to the internet, and on the Sonic Wall I believe that there is a route going to the proxy-server with the 3750x as the next hop. (Sorry but I am all just assuming the routing since I am not really an expert on Sonic Wall firewall.  But I believe that there is a default route to the Sonic Wall if ever no routes.
In replacing the Sonic Wall firewall, the client required for the 2 ASA's to do the interVLAN routing and pose as gateways for the internal LANS, and also for the DMZ's for the future.
Now the 2 ASA's will have connections to the 3750x.
Please let me know what else is not clear so I can clarify.
* I have added the nameifs on the subifs
!SWITCH CONFIG
interface Vlan600
 standby 1 preempt
!FIREWALL CONFIG
Port-channel 5.2
 nameif LAN1
 lacp max-bundle 8
 vlan 2
 description LAN1
 security-level 100
 speed 1000
 duplex full
Port-channel 5.3
 nameif LAN2
 lacp max-bundle 8
 vlan 3
 security-level 100
 speed 1000
 duplex full
Port-channel 5.52
 nameif LAN3
 lacp max-bundle 8
 vlan 52
 description LAN3
 security-level 100
 speed 1000
 duplex full
port-channel 5.200
 nameif LAN4
 lacp max-bundle 8
 vlan 200
 description LAN4
 security-level 100
 speed 1000
 duplex full
port-channel 5.600
 nameif FW-INTERCONNECT
 lacp max-bundle 8
 vlan 600
 security-level 100
 speed 1000
 duplex full
 speed 1000
 duplex full
 no nameif
 no security-level
 no ip address
Ok, if the ASA does the internal routing, then you don't need any static routes for that LANs that are terminated on the ASA.
And if all VLANs are terminated on the ASA, then you probably don't need the FW-Interconnect subinterface on the ASA and the VLAN on the 3750. You only need it if you want to separate the management of the 3750.
so other than description on port-channel5.600 (I can make this MANAGEMENT), the configs I posted are spot on and no changes should be made?
!SUMMARY
!SWITCH CONFIGURATION
have 2 port-channels, port-channel5 to the standby, port-channel6 to the active
ip route 0.0.0.0 0.0.0.0 10.136.255.236 -> active ip of firewall
no need to use SVI 600 3750x?
!FIREWALL CONFIGS
have port-channel5 only
port-channel5.x on all internal vlans including vlan 600 if will be used for another service
Please let me know so I can shake your hand and probably buy you a beer if you are in UK...
Without vlan 600, the switch needs a management-ip from one of the other vlans. The default-route will point to the ASA in the van where the management-IP will be.
No trip to UK planned for the moment, But I'll remind you about the beer if I travel there ... ;-)
Ok, so my default route is not one of the subnets I have defined... it's the management IP subnet for all the network devices is that it (existing already and it's vlan1000)
interface Management0/0
 speed auto
 duplex auto
 management-only
 nameif management
 security-level 100
 ip address 10.136.253.11 255.255.255.0 standby 10.136.253.12
 delay 1
so:
ip route 0.0.0.0 0.0.0.0 10.136.253.11
is this correct?
