How to configure SPAN from local and remote port
Nguyen KeThuc
Hi all,
Now, I have two cisco Switches ( 3560) ( Sw1 and Sw2).They connect to each other via trunk port. I want to configure span from port g0/1 in Sw1 and port g0/1 in Sw2 to port g0/2 in Sw1.
Could you show me how to configure this ?
Thuc
Ganesh Hariharan
Hi all,
Thuc
Hi Thuc,
Check out the below link for span and rspan configuration in cisco 3560 switches
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swspan.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Hi Ganesh,
I reviewed your web page. I configured :
SW2(config)#Vlan 11
SW2(config-vlan)#remote-span
SW2(config-vlan)#exit
SW2(config)#monitor session 1 source interface Gi0/1
SW2(config)#monitor session 1 destination remote vlan 11
SW1(config)#Vlan 11
SW1(config-vlan)#remote-span
SW1(config-vlan)#exit
SW1(config)#monitor session 1 source interface Gi0/1
SW1(config)#monitor session 1 destination interface g0/2
SW1(config)#monitor session 1 source vlan 11
% Cannot add VLANs as sources for SPAN session 1
I also tried this command:
SW1(config)#monitor session 1 source remote vlan 11
% Cannot add RSPAN VLAN as source for SPAN session 2 as it is not a RSPAN Destination session
My issue is you cannot mix ports and VLANs in a single session. Do you have any ideas?
Thuc
