how to configurie ASA for intervlan with Switch 2960L2
shine pothen
Level 3
Level 3
hi all
i have 2960 l2 switch connected to the ASA 5505. for some or the other reason i am not able to do intervlan communication.
have done trunk mode on both ends onthe switch as well as on the ASA and native vlan 1 allowed. the trunk is up up i am able to poing only the vlan 1 ip from the switch to the ASA for the vlan 2 i am not and simillar for vlan 3.please help me in fixin this
config on the ASA
ASA Version 8.2(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
description Inside Lan UK
nameif inside
security-level 100
ip address 192.168.50.5 255.255.255.0
interface Vlan2
description Internet
nameif outside
security-level 0
ip address 192.168.51.1 255.255.255.248
interface Vlan3
no nameif
security-level 100
ip address 192.168.52.254 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport trunk allowed vlan 1-3
switchport trunk native vlan 1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
access-list acl_in extended permit icmp any any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route inside 0.0.0.0 0.0.0.0 192.168.50.5 1
route inside 192.168.0.0 255.255.0.0 192.168.50.5 1
route inside 192.168.52.0 255.255.255.0 192.168.50.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 192.168.50.5 255.255.255.255 inside
ssh 192.168.51.1 255.255.255.255 outside
ssh timeout 60
ssh version 2
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
Cryptochecksum:862ed74b43dd84b4825fda278227c8ae
: end
ciscoasa#
ciscoasa#   ping 192.168.50.10
Sending 5, 100-byte ICMP Echos to 192.168.50.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ciscoasa#
and on my switch i have created four vlan i am just trying to communciating with atleast two vlans
interface Vlan1
ip address 192.168.50.10 255.255.255.0
no ip route-cache
interface Vlan2
description Server EXS4
ip address 192.168.52.1 255.255.255.0
no ip route-cache
--More--         interface Vlan4
description Storage ISCI
ip address 192.168.54.1 255.255.255.0
no ip route-cache
interface Vlan6
description Desktop Users
ip address 192.168.56.1 255.255.255.0
no ip route-cache
pleaselet me know the necessary steps that i have to do to make the communication work. between the switch and the ASA
thanks
Fabienne Stephanoff
Hello Shine,
This board will take care of the switch side but you may want to open a separate discussion on the security board to address the ASA side of things.
Can you provide me with the following outputs from the switch side:
- show vlan
- show int trunk
Fabienne - LAN-Switching TAC
cadet alain
on the switch side you don't need to have vlan interfaces, just configure the port going to asa eth0/1 as an unconditional trunk port with switchport mode trunk command then configure access ports for the corresponding vlans.
If you've got interfaces with same security-level on the ASA and you want traffic to traverse these interfaces then you must configure same-security-traffic permit inter-interface  global command command and also do nat for these interfaces.
Alain..
