1811 will not do NAT
umbernaut
(I hope this is the proper place to post a NAT/routing question; if not, please move or let me know)
Some time back, I successfully configured a 2811 to do NAT.  I am having difficulty with an 1811 router using the same config.
Here is the 2811 config that successfully performed NAT from our private to public:
(I've removed everything except the critical information)
interface FastEthernet0/0
ip address [public ip] 255.255.255.240
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex half
speed auto
no mop enabled
ip nat pool [name] [public ip] [public ip] prefix-length 30
ip nat inside source list 1 pool [name] overload
ip route 0.0.0.0 0.0.0.0 [public gateway]
access-list 1 permit 192.168.1.0 0.0.0.255
Here is the 1811 config that will not do NAT:
ip nat outside
speed auto
half-duplex
interface FastEthernet1
ip address 172.16.1.1 255.255.255.224
ip nat inside
speed auto
half-duplex
access-list 1 permit 172.16.1.1 0.0.0.31
IOS version on the 1811 is:
Version 12.3(8r)YH12
Any help/advice is appreciated
jaimedrq1
Hi Umbernaut,
Why you don't try instead of using a pool the next command:
ip nat inside source list 1 interface fa 0 overload
If you have only one direction the pool is not needed.
Check the ip address where you are doing the connection, it should be between 172.16.1.1 and 172.16.1.30
I hope this helps
Cheers
Jaime.
umbernaut
I made the change you recommended, but it still wouldn't work.  I changed the duplex on both interfaces from "half-duplex" to "duplex auto" and it works now!
