How to connect a wifi-router to a Cisco Switch
pgm4
Dear all experts,
I have Asus router connecting to a switch and wants to provide wifi service to my clients.  My switch is 2950 model and the router is RT-AC66U.  I have set the router to AP mode and obtains static IP.  I use one of the LAN port in my router and connect it to one of my Cisco switch port.
Do I need to enable the Cisco switch port (connect to Asus router) to spanning-tree portfast?  Or I should set it to no spanning-tree.  I have read some articles from internet which said it should be set 'no spanning-tree' for hubs.  However, I just used wifi feature for that Asus router.  I feel confused about that.  Moreoever, do I need to set that port toe be trunk mode? Or just leave it to access mode?  Thanks for your help.
Jerry Paul
You should set the port as static trunk port.
