How to connect Catalyst 2960-S F/O Port (using glc-lh-sm 30-1299-03 SFP) with Raisecom RC001 Media Converter or with any Third Party switch ?
hm_farooqui
Hi All,
<<2960-S- F/O Gi 1/0/25 SFP>> --- F/O----<< Raisecom RC001 Media Converter>> --Copper- << Third Party Switch>>
On one end I've Raisecom RC001 1slot media convert (connected with the Copper Switch) and on other end I want to connect  Catalyst 2960-S with GLC-LH-SM 30-1299-03 SFP module. (Distance 5 KM).
I was using Zyxel GS2210 switch before which got faulty and I don't have the same to replace it. I've just Catalyst 2960-S  available to make the link up.
Please guide me how can I establish the link between F/O Port  of 2960 and Raisecom RC001 1 slot Media Converter ?
I also have following SFP modules , kindly also tell if they could help me in this regard?
GigaLight GP-3124-L2CD 1.25G SFP
HP RTXM191-400
Sincere Regards,
the link below shows you which transceivers are compatible with your 2960S. As for connecting the switch to a third party device such as your Zyxel, it usually comes down to trial and error, as there is no comprehensive documentation on which converter works with which third party device...
https://tmgmatrix.cisco.com/?npf=2
